1. superjoe95's Avatar
    I know this is a long shot but I'm going to ask anyways. Anyone know if there is an extended battery out there for the S3 where the replacement battery and battery door are thin enough to still fit an OtterBox Commuter case? I figure with the flexible silicon and the thin plastic shell that it might be able to fit something.
    05-17-2013 07:22 PM
  2. geekymcfly's Avatar
    i believe you can use any 4500mah extended battery with some modding to the commuter case
    05-17-2013 10:04 PM
  3. superjoe95's Avatar
    What are some of the best 4500mah batteries out there? What kind of moding would we be looking at?
    05-17-2013 10:12 PM
  4. geekymcfly's Avatar
    I had a hyperion 4200mah extended battery, couldnt tell you about the rest. but I'm thinking that you'll have to somehow mod the plastic piece on the OT Commuter. but if it's one piece not sure if it'll work
    here's a idea
    05-18-2013 08:08 AM
  1. Extended Battery and Otterbox?
    By cyberchief in forum Samsung Galaxy S3
    Last Post: 10-24-2012, 10:13 AM
  2. Extended battery and Otterbox case
    By KeepOnSingin in forum Verizon Galaxy S III Accessories
    Last Post: 08-10-2012, 09:23 PM
  3. FS: Droid X WITH extended battery and cover
    By NickB2005 in forum Marketplace Archive
    Last Post: 03-28-2011, 08:34 PM
  4. Replies: 21
    Last Post: 09-03-2010, 10:15 PM
  5. Extended Battery and Case
    By CRKhead in forum Incredible Accessories
    Last Post: 05-10-2010, 12:47 PM
