1. itsFroyo's Avatar
    So my boyfriend also has a Samsung Galaxy S3 and has been complaining that my texts are arriving much later (usually 15 - 30 minutes) after they send. When they do arrive they arrive all at once. I was wondering if this was a problem with my phone or his. Also, what can I do to fix it? Another problem I've been facing is sometimes when I call someone it'll sound extremely robotic and choppy, even when I'm just in my room. Any help in these matters would be super appreciated!!! Thanks for reading!
    05-24-2013 12:18 AM
  2. GSDer's Avatar
    Are you both on the same carrier?
    Are you both using the same Messaging app?
    If you're sending SMS (no attachments, < 160 characters), that totally relies on your cellular signal - what kind of signal do both of you have (3 bars or more, hopefully)?
    What happens when each of you text someone else - does that go through normally?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    05-24-2013 01:03 AM
  3. Roll_Cam_Tide's Avatar
    Depending on the carrier, you could try updating your roaming capabilities. On Verizon I believe you dial *228 and select option 2.
    05-27-2013 02:47 PM
  1. Problems with sending texts:
    By imsofinite in forum Verizon HTC Thunderbolt
    Last Post: 01-02-2012, 03:15 AM
  2. Replies: 1
    Last Post: 07-21-2010, 01:11 AM
  3. Replies: 3
    Last Post: 07-19-2010, 09:29 PM
  4. Replies: 3
    Last Post: 06-22-2010, 12:58 PM
  5. I'm having a problem with the Gmail app.
    By BurgesS in forum General Help and How To
    Last Post: 03-05-2010, 08:33 AM
