1. SHCHN's Avatar
    I am new here, sorry if i have broken any rules!! So, i have been having my S3 for like a week now and the battery is draining like crazy. I have read a dozen forums, followed all suggestions, but still no improvement. This is my 2nd battery had the 1st one changed as i thought maybe it was the battery, also changed the charger but the problem persists. Any help will be appreciated. Here are some screen shots that i have just taken, hope they shade some light!!
    Attached Thumbnails Samsung GS3 battery drain-screenshot_2013-05-26-00-17-11.png   Samsung GS3 battery drain-screenshot_2013-05-26-00-17-23.png   Samsung GS3 battery drain-screenshot_2013-05-26-00-17-35.png   Samsung GS3 battery drain-screenshot_2013-05-26-00-17-43.png
    05-25-2013 12:45 PM
  2. meyerweb#CB's Avatar
    I don't see anything obvious as to the cause, but you're right, that's excessive drain. You've had the screen on for about half the time since the phone came off the charger, so 50% of usage being for the screen doesn't seem off, but losing 40% in about 3 hours does.
    What are the shield notification and warning sign notifications for?
    Take a look at this thread, and see if the techniques I used there point out any app that's causing problems. http://forums.androidcentral.com/sam...ery-check.html
    SHCHN likes this.
    05-25-2013 04:25 PM
  3. SHCHN's Avatar
    Thanks, meyerweb, i followed the link you provided, i monitored the cpu usage and didn't notice any weird processes but will continue doing so. The notifications are for juice defender and gsam battery monitor. So , i went to bed last night shortly after making the post, i was at about 63% and 5hrs later when i woke up i was at 9%. The network at my place is rather doggy at times, so am wondering if its the cause? Here are some screen shots from this morning, gsam saying phone radio 81.6 %. could that be the problem?
    Attached Thumbnails Samsung GS3 battery drain-screenshot_2013-05-26-06-15-56.png   Samsung GS3 battery drain-screenshot_2013-05-26-06-33-47.png   Samsung GS3 battery drain-screenshot_2013-05-26-06-34-00.png
    05-25-2013 10:30 PM
  4. SHCHN's Avatar
    and here is the graph from the battery usage over night.
    05-25-2013 10:33 PM
  5. meyerweb#CB's Avatar
    A weak radio cellular signal definitely drains the battery faster, especially if data is enabled. Do you have WiFi at home? If so, connecting to WiFi, and setting Keep Wi-Fi on during sleep to "Always." will help.
    But there appears to be something else going on. In your last screen shot, the Awake row shows that something is keeping your phone from going into deep sleep after you've put it down for the night. That's probably your biggest culprit. This could be things like background data syncing of email, facebook, use of location / check-in services, or many other things. Install the app Wakelock Detector from the Play store, take it off the charger just before you put it down for the night again, and then first thing in the a.m. see what wakelocks are using the most resources. Do a screen capture of that and post it here. (The app Better Battery Stats provides more data than WD, but WD is free, so try that one first.)
    Also, check out this thread on battery life: http://forums.androidcentral.com/sam...ips-myths.html
    05-26-2013 10:20 AM
  6. SHCHN's Avatar
    I have wifi, but it seems as if i have problems connecting to the wifi at home but outside my place it doesn't give a problem so i use a lot of mobile data when at home seems better than wifi, and this is always off when not in use. Dont have facebook, disabled all syncing. Am downloading the Wakelock app now, will post again with the screen shots! Thank you.
    05-26-2013 10:33 AM
  7. vre's Avatar
    Your phone has massive wake locks. Due to kernel preventing the phone to go to deepsleep or apps causing it. I think it is both as you are using Samsung stock as it seems. Please install BetterBatteryStats and post the result here.
    05-26-2013 10:40 AM
  8. vre's Avatar
    I'm pretty sure it has to do with fast dormancy keeping your device awake. As i said install BetterBatteryStats and we will know for sure
    05-26-2013 10:42 AM
  9. SHCHN's Avatar
    Slight problem, seems can't download Wakelock Detector from this end ( China), is there any other app that i can use instead of wakelock detector?
    05-26-2013 10:42 AM
  10. vre's Avatar
    Yes.... BetterBatteryStats. As i already mentioned.
    05-26-2013 05:04 PM
  11. SHCHN's Avatar
    Been away for a while, but unfortunately my battery problems still persist. I finally managed to download Better battery stats and wakelock detector. Here are some screen shots that i took yesterday. Went to bed with a full battery and when i woke up some 8hrs later, battery was down to 34%! Please help, not sure what to do with all the info on better battery stats and wakelock detector!
    Attached Thumbnails Samsung GS3 battery drain-screenshot_2013-06-05-09-36-45.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-37-24.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-36-10.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-32-43.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-33-40.png
    Samsung GS3 battery drain-screenshot_2013-06-05-09-34-11.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-42-51.png   Samsung GS3 battery drain-screenshot_2013-06-05-09-44-50.png
    06-05-2013 11:28 AM
  1. Samsung S3 battery drain
    By dark twister in forum Samsung Galaxy SIII I9300
    Last Post: 07-19-2013, 09:23 AM
  2. All Share Play to Samsung Link = battery drain
    By vr002sh in forum Samsung Galaxy Note 2
    Last Post: 05-20-2013, 10:22 PM
  3. Samsung GS3 Battery: Enough to make me throw this phone away
    By iFall3n in forum General News & Discussion
    Last Post: 04-14-2013, 02:43 PM
  4. Tmobile Samsung s3 battery drain
    By Cadeveloper27 in forum T-Mobile Galaxy S III
    Last Post: 04-03-2013, 01:55 PM
  5. Samsung Infuse Battery Drain after root
    By tnksemperfi in forum General Help and How To
    Last Post: 07-08-2011, 01:39 PM
