1. David Android's Avatar
    I am trying to run the MyFirstApp tutorial from developer.android.com from Eclipse on Windows 7. When I try to run on my Samsung Galaxy 3 device the application seems to run OK but nothing seems to happen. I have also tried running the same application on a virtual emulator, once again where nothing seems to happen. Trying to work out out how to run my Android applications.
    Here is the code in MainActivity.java:
    Code:
    package com.example.myfirstapp;
    import android.app.Activity;
    import android.os.Bundle;
    import android.view.Menu;
    public class MainActivity extends Activity {
    	@Override
    	protected void onCreate(Bundle savedInstanceState) {
    		super.onCreate(savedInstanceState);
    		setContentView(R.layout.activity_main);
    	@Override
    	public boolean onCreateOptionsMenu(Menu menu) {
    		// Inflate the menu; this adds items to the action bar if it is present.
    		getMenuInflater().inflate(R.menu.main, menu);
    		return true;
    David
    05-29-2013 04:58 AM
  2. trucky's Avatar
    You might get better assistance in the forum that supports that dev code tutorial...
    https://groups.google.com/forum/?fro...oid-developers
    05-29-2013 06:24 AM
  1. What apps should be running in the background?
    By clevan3 in forum Verizon Galaxy S III
    Last Post: 09-11-2012, 08:32 AM
  2. Running Services - What Should be Running?
    By robbieas in forum T-Mobile G2x
    Last Post: 06-23-2011, 08:16 PM
  3. OTA Update message on my X running ApeX v1.0.2.2. What should I do?
    By PsychicRefugee in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 12-25-2010, 10:49 AM
  4. From Pre to Hero, what should I expect?
    By kehanra99 in forum HTC Hero
    Last Post: 11-19-2009, 02:12 PM
  5. What should I know or do when I get my Droid?
    By Tghockey07#AC in forum Motorola Droid
    Last Post: 11-10-2009, 01:54 PM
