Im so glad that I have found a thread with so many people with the same issue as me!
I've been living with this issue for probably around 4 or 5 months now. My phone is around a year and a half old and the problems started around 11 months of me owning the phone. It happened totally out of the blue one night, as I plugged in the charger to my Samsung S3 the bleeping charging noise sounded and I pressed the lock button so that the screen would go to sleep, after turning over to go to sleep I heard another beep and noticed that the screen was flashing quite rapidly. I looked at the phone and noticed that S voice, driving mode and docking mode was all opening and closing itself by its own accord. Unplugging the charger and plugging it back in caused the same issue. Luckily my old Nokia N8 came with a micro USB that I tried and LUCKILY this charged the phone, so I put it down to a faulty charger. Looking at the pins on my old the next morning, (the one that came shipped with my s3) I noticed one of the pins inside of the micro usb had snapped off, so I put it down to that.
Unfortunately the problem reappeared a month or two later, this time the charger would only charge when it was at an angle, i.e. the micro usb section which fits in to the s3 had to be pressed “up” slightly for it to recognise the charger. This meant I had to hold the charger flat in my hand and very gently press the charger wire upwards (have other people tried this?). This time instead of trying another charger I thought Id take it to have it looked at/ repaired. I purchased extra insurance when I bought the phone so I thought why not try? I made arrangements to have the phone sent off to Tesco mobile (where I purchased the phone from). After a fortnight of hearing nothing I got the phone back in the post, a letter inside stated that they found no problems with the phone but they had updated the software on the phone. I thought theirs no way it could be software related as the charger is hardware! I tried my girlfriends old HTC charger and it charged straight away.
Now skip forward a couple of months and ive had no problems with the phone until last week, yet again its completely out of the blue. I had been charging the phone on and off all day as I was busy and everything was working fine. Later on in the day I plugged in the phone and it charged, until I noticed that the blue LED on the front of the phone wasn’t flashing, I pressed the lock button on the phone to check and the phone wasn’t charging. From past experience I tried pressing the charger “upwards” again, and it charged until I let go of it. Now I am back to square one.
I have spent quite a lot of time reading other forums about this issue, one solution that I have found is cleaning inside of your phones USB port. I have found that doing this does unearth a lot of dust/lint. Even this morning I managed to get quite a sizeable ball of fluff out of it. My phone is now opening S voice of its own accord whilst charging, but at least its still charging. Its on charge again now and has been for the past half an hour and no S voice or docking mode has appeared so far (touch wood).
So I suggest to you guys to gently try and clean the pins on your phone and try along the corners and ‘drag’ it upwards to see if you can get any dust/lint out. You don’t have to be forcefully, just gently brush/ stroke upwards. If I find my problem has disappeared in the next few days, Im DEFINTELY putting it down to this problem. I have also stumbled across this from amazon: a usb cover and it’s only ?1.49 so it cant hurt to try out!
http://www.amazon.co.uk/Cover-Stopp...ag=hawk-future-21&ascsubtag=UUacUvbUpU3109640
