1. seon kim's Avatar
    please help me.
    I replaced glass because I dropped my phone and had cracks on upper corner.
    after turned on power, no screen but black.
    when I press menu button, there are two lights each side of menu button(home and back button)
    is there anyone knows why? and how can i fix?
    06-10-2013 07:08 PM
  2. bosshaug12's Avatar
    Why?
    You broke the AMOLED display during your attempt at replacing the lens.
    How to fix it?
    Replace the entire lens/AMOLED assembly. Rough cost is around $240.
    seon kim likes this.
    06-10-2013 07:15 PM
  3. DroidXcon's Avatar
    please help me.
    Seon, welcome to Android central. It is possible that the ribbon connecting the screen to the rest of the device is not seated well , you may need to disassemble and check that it is connected properly
    06-10-2013 07:19 PM
  4. Boyi Jiang's Avatar
    have you fixed the problem? I have the same exact problem! Don't know what to do..
    10-14-2013 02:04 PM
  5. GSDer's Avatar
    Go to http://m.repairsuniverse.com/samsung...ent-white.html and get a replacement assembly (~$170; be sure to get the correct color for your phone).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-14-2013 02:36 PM
  1. SGH-T959w 4g has no data after root and unlock
    By jimmyhoffa53 in forum T-Mobile Galaxy S 4G
    Last Post: 05-28-2013, 07:26 PM
  2. after replacing screen galaxy s3 . help!
    By Marycarmen Diaz in forum Samsung Galaxy S3
    Last Post: 04-02-2013, 12:25 PM
  3. My phone has no signal after flashing Blaze_4G_LB7_ICS PLS HELP
    By skystar3 in forum Samsung Galaxy S II Skyrocket
    Last Post: 07-21-2012, 10:55 AM
  4. Nexus S has no cell service after OTA
    By webb3201 in forum AT&T Nexus S
    Last Post: 10-03-2011, 04:21 PM
  5. is a screen digitizer the same as a replacement glass?
    By quixoticelixer in forum AT&T ATRIX
    Last Post: 07-12-2011, 09:18 AM
