1. Boatman's Avatar
    I tried to access Google Play Store today, only to be asked for a Password. I have treid evey password I can think of, still cannot access PlayStore.
    I don't remember being asked for a password at this stage before.
    Does anybody know what might have changed and/or WHICH password I need (I am already IN the system in order to be able to see the Play Store icon)?
    Many thanks in advance
    Boatman
    06-16-2013 01:37 PM
  2. Paul627g's Avatar
    If your accessing it from your device then the only password I know of which can be added is if you OPT to add a password protection to allow purchase of apps that require payment. Otherwise you should be able to access the Play Store from your device.
    06-16-2013 01:41 PM
  3. Robert White1's Avatar
    Use your gmail login and password
    06-16-2013 02:10 PM
  4. Boatman's Avatar
    Thanks all for responses. The problem has now disappeared, but as far as I know I didn't do anything to the Android to make this happen!
    06-20-2013 07:11 AM
  1. A problem with my TM GS4,,,, was it my GS4 or TM's fault ?????
    By Davyo in forum T-Mobile Samsung Galaxy S4
    Last Post: 06-12-2013, 12:27 AM
  2. Replies: 22
    Last Post: 01-14-2011, 08:36 PM
  3. A few little problems with my Droid. I call upon you!
    By GenericMessage in forum Motorola Droid
    Last Post: 02-03-2010, 08:34 AM
  4. Problems with my email
    By jdaly in forum Motorola Droid
    Last Post: 12-28-2009, 09:29 PM
  5. I'm so close to returning my Droid! But it's not my fault!
    By cheechoz818 in forum Motorola Droid
    Last Post: 12-22-2009, 11:13 AM
