1. Arild Haugen's Avatar
    My S3 doesn't receive input anymore! It looks like the phone works fine, but I can not write anything. Hence, can not insert PIN, initiate backup etc. Has bought a new phone and only needs to access some apps to transfer data (all that's in Google Play is OK). Can I operate it remotely from my PC, for instance? Any tips?
    06-22-2013 12:39 AM
  2. DroidXcon's Avatar
    Welcome to Android Central, was your device rooted. If it was not I do not think there is a way to do so.
    06-22-2013 02:27 AM
  3. GSDer's Avatar
    Have you tried a battery pull (leave the battery out for a couple of minutes) to see if this resolves the problem?
    Unfortunately, that's one of the limitations of having security enabled - if the touchscreen stops responding, there's no way to enter the security key (Pattern, PIN, password) to be able to access the contents of the phone. There may be a way to accomplish that using ADB or the development environment but I'm not knowledgeable in that area, sorry.
    You could try booting in Recovery mode (with the phone turned completely off, press and hold the Volume Up & Home & Power buttons simultaneously - once you see the splash screen you can release them all) and wiping the cache, but I'm doubtful that will help in this instance.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    06-22-2013 09:50 AM
  4. annoyedandsuffocated's Avatar
    I type but its very slow and looks like its blocked. Yellow box comes up first before constantly tapping. How do I unblock?
    08-01-2013 06:10 PM
  5. GSDer's Avatar
    I'm not sure what you're trying to describe.
    Is this weird behavior happening during boot up?
    Only when you're using the keyboard to type?
    Can you post a screenshot of what you're seeing?
    Which keyboard are you using?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4 Beta
    08-01-2013 11:02 PM
  1. S3 Bluetooth Does NOT Auto Connect to Car
    By FishMeetFish in forum Samsung Galaxy S3
    Last Post: 02-23-2016, 09:42 PM
  2. SD card does not read on my HTC One V
    By JasonTheGiantsFan in forum HTC One V
    Last Post: 02-17-2013, 10:29 PM
  3. S3 mail app does not read email sent from Iphone
    By hsiegal30 in forum Verizon Galaxy S III
    Last Post: 08-26-2012, 09:39 PM
  4. Samsung Droid Charge is not reading my SIM card!?
    By AnjanVS94 in forum Verizon Droid Charge
    Last Post: 04-09-2012, 07:42 PM
  5. Touchscreen does not work when in phone mode
    By clb239 in forum Virgin Mobile Optimus Slider
    Last Post: 12-30-2011, 02:49 PM
