1. Lennontv's Avatar
    Hello hello. I've recorded a video on my phone andfor some reason iI'm unable to view it. Says unsupported format. Most of my other videos go. Next to the video in the dcim folder it says it has 50mb recorded but the time length is 0.00. I've tried almost every video player on the play store and when I tried using a video cutter and converter it says no file? It's obviously recored something but hasn't formated I don't know. Would love to get this video going with any help.
    Thanks
    06-30-2013 08:05 PM
  2. jollyxier's Avatar
    Hi friend! Do you know the recording video format of your phone? Generally it's 3gp or mp4. If your video's extension name isn't .3gp or mp4. That means there's something wrong when you was recording the video. Maybe your phone has some problem. Anyway, you can use a powerful video converter like Handbrake or Aneesoft video converter to convert it. But, I think you should check your phone.
    07-04-2013 02:44 AM
  3. GTWalling's Avatar
    If you are saving to the External SD the card may be going bad and corrupting the Videos.
    07-04-2013 05:55 PM
  4. GSDer's Avatar
    ^ What he said
    It sounds like that particular video file got corrupted.
    You may want to try something like Cloud Drive: http://market.android.com/details?id...uddrive.photos just in case your SDCard is the culprit.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    07-04-2013 06:30 PM
  1. OUT OF THE POT and JUMPIN INTO FLAMES . ROM Issue PLEASE HELP :(
    By URBANDISCIPLE in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-01-2013, 07:45 PM
  2. OUT OF THE POT and JUMPIN INTO FLAMES . ROM Issue PLEASE HELP :(
    By URBANDISCIPLE in forum Verizon Samsung Galaxy S4
    Last Post: 07-01-2013, 09:41 AM
  3. Inappropriate switch off problem
    By Fadi_1992 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-30-2013, 06:41 PM
  4. plz need solution siii problems
    By Margarvy Valcin in forum Samsung Galaxy SIII I9300
    Last Post: 06-30-2013, 05:11 PM
  5. Video Playback constantly buffering
    By alc2077 in forum LG Optimus G Pro
    Last Post: 06-30-2013, 03:43 PM
