1. AJ7's Avatar
    Hi all got a Skin to my phone and the top right and press pealing to'll hit back and surprise me is that I heard a small sound, remove the lid and followed, here is a video so you can see
    07-04-2013 01:54 PM
  2. meyerweb#CB's Avatar
    I can't make out anything on that video. It's too dark. Can't you turn on a brighter light?
    07-04-2013 03:46 PM
  3. AJ7's Avatar
    Hello my galaxy s3 in the top corner of the flash makes a sound when you pressure is what I show in the video
    07-04-2013 09:07 PM
  4. GSDer's Avatar
    It's not a cat - you're not supposed to be petting it
    Frankly, I can't tell what the heck you're doing. Looks like you rub the case a couple of times, then press on the corner, but I can't see what you're trying to explain.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    07-04-2013 09:29 PM
  5. AJ7's Avatar
    in the video it seems that I cherish but actually to some pressure down and if you give the volume sounds better
    07-04-2013 09:45 PM
  6. AJ7's Avatar
    no test remove the lid and squeeze a little in various parts to see if it sounds??
    Only takes 2 minutes
    - - - Updated - - -
    07-05-2013 02:11 PM
  1. Access video library from PC on my Nexus 7
    By underdog2 in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-15-2013, 02:23 AM
  2. when connected to TV via HDMI cable, does the Note 2's screen stay on?
    By Kiersten_Kress in forum Verizon Galaxy Note 2
    Last Post: 07-05-2013, 02:51 PM
  3. Software update error... phone no longer turns on
    By Casey Leeson in forum General Help and How To
    Last Post: 07-04-2013, 08:50 PM
  4. Apps closing on their own
    By henryfool3 in forum HTC One M7
    Last Post: 07-04-2013, 05:47 PM
  5. Replies: 0
    Last Post: 07-04-2013, 01:16 PM
