1. Motunrayo Balogun's Avatar
    I noticed that while I charge my phone the battery percent goes down even though it is in the charger.
    Attached Thumbnails Battery draining while charging-uploadfromtaptalk1373476442924.jpg   Battery draining while charging-uploadfromtaptalk1373476454481.jpg   Battery draining while charging-uploadfromtaptalk1373476465277.jpg
    07-10-2013 12:14 PM
  2. paintdrinkingpete's Avatar
    That usually means that your phone is using more power than supplied by the charger. Are you using the supplied charger that came with the phone, or a different one?
    Something is eating up power on that phone, at the very least I'd reboot it to see if that helps, though with your battery that low you may want to charge it for a few minutes with the phone shutoff before powering it back on...
    07-10-2013 12:50 PM
  3. meyerweb#CB's Avatar
    Are you connecting to a charger, or to a computer? Either way, try the other, and try using a different USB cable.
    07-10-2013 04:06 PM
  4. SlntAgent's Avatar
    my battery life has been horrible and really slow charging times since Verizon last updated the phone....i feel your pain
    07-10-2013 08:58 PM
  5. Motunrayo Balogun's Avatar
    I am using the charger it came with. I connect it to an outlet. I tried a different usb and it charging now.
    07-11-2013 08:34 AM
  1. Replies: 116
    Last Post: 08-17-2016, 09:32 AM
  2. Replies: 4
    Last Post: 09-15-2013, 06:02 AM
  3. I simply can not get good battery life with this phone!
    By BlackPrince310 in forum HTC One M7
    Last Post: 08-28-2013, 01:11 AM
  4. The best energy saver or battery booster
    By benitto in forum Android Apps
    Last Post: 07-10-2013, 11:30 AM
  5. The best energy saver or battery booster
    By benitto in forum Android 4.0 Ice Cream Sandwich
    Last Post: 07-10-2013, 10:33 AM
