1. Sandy Gerli's Avatar
    Hi, Everyone!
    I have a new Galaxy S3. I've rooted it, and installed a 32GB MicroSD Card. Now, I'm trying to transfer all my music to the SD Card. However, my program (doubleTwist), seems to have tried to load everything to the S3's main memory, which is only 16GB. Of course, since I have 18GB of music, that isn't going to work! I have received a warning in the "STORAGE" section of my Settings which tells me to free up space by deleting data or apps. The "Application Manager" in Settings just chooses tracks, won't delete any.
    First, how do I delete the music files that were loaded? More importantly, how do I set the S3 up to transfer all my music data to the SD Card, NOT to the phone's internal memory? I can't seem to figure out how to enable that. The S3 recognizes the SD Card and has formatted it just fine, and says I have 30+GB available space, but nothing has been stored on it.
    Also, the transfer I did was terribly slow. Took 10 hours plus to transfer the data that was accepted.
    Hope someone can help me with this! I can be reached off-forum at - ac1wye at gmail dot com
    Thanks, gang!
    Sandy Gerli
    Mount Airy NC
    07-11-2013 12:41 PM
  2. Kris Simundson's Avatar
    Enable USB Mass Storage, you SD will mount to your PC, copy all music into a music folder, disable USB Mass Storage
    To delete media quickly, connect device to PC, open file explorer, find doubletwist folder, or where ever it stored the music, highlight all and delete
    07-11-2013 12:52 PM
  3. GSDer's Avatar
    For your first question - I'd think there'd be a way to do that from within DoubleTwist: I mean, it would be silly to allow you to install music without being able to remove it. If that doesn't work, though, then you could use any file manager to look for a DoubleTwist directory on sdcard0 - all your music should be in there, so if you delete the directory that should take care of your problem.
    Of course, if you want to put that content on your SDCard, then you're better off copying that directory to your SDCard first (or using the "Move" command if your file manager supports it) and THEN deleting it.
    For your second question, there should be some way within DoubleTwist to specify the destination for local content (sorry, I'm not a DoubleTwist user so I can't say for sure).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
    07-11-2013 05:55 PM
  4. AxlMyk's Avatar
    I use ES FILE MANAGER over wifi to access my PC files, and transfer to the phone, or phone to PC transfer.
    Just make sure the PC folders are shared.
    --Tapatalk on SGS3.
    07-11-2013 09:48 PM
  5. GTWalling's Avatar
    Google did away with Mass Storage with the 4.1.1 ICS update.
    07-11-2013 10:17 PM
  1. Can't identify this icon in my status bar? Wavy N shape?
    By nadiainthesky in forum HTC One M7
    Last Post: 04-03-2015, 05:27 AM
  2. Grey wifi bars - need to turn BLUE
    By elbacchus in forum Samsung Galaxy 3
    Last Post: 09-01-2013, 07:18 PM
  3. delay in loading home screen
    By gavril in forum Android 4.0 Ice Cream Sandwich
    Last Post: 07-14-2013, 05:06 AM
  4. Galaxy S4 Dropping calls, only way to reconnect is to reboot
    By AMG_Roadster in forum Samsung Galaxy S4
    Last Post: 07-11-2013, 11:31 AM
