1. tony477g's Avatar
    I usually have my phone connected to the aux cable when im driving, today i noticed it had driving mode, i turned it on i sent myself a text but nothing happened, so i just shut it off again, am i supposed to do something to make it work. Or does it just do nothing?
    07-13-2013 11:50 PM
  2. meyerweb#CB's Avatar
    I believe all it does is read incoming text messages, and possibly emails.
    07-14-2013 12:01 AM
  3. tony477g's Avatar
    will it work if im using hand cent, or swift key?
    07-14-2013 12:55 AM
  4. meyerweb#CB's Avatar
    I don't think the keyboard will make a difference. Not sure about handcent. Also, you need to have s-voice enabled.
    07-14-2013 11:20 AM
  5. tony477g's Avatar
    how do you enable it? yesterday it started working, but all it did was said new text from so and so, really defeats the purpose if you still have to read it
    07-14-2013 07:35 PM
  6. meyerweb#CB's Avatar
    I haven't actually used driving mode, so I'm not totally sure about this, but...The s-voice icon should be in your app drawer. Tap to open, then tap menu / settings. You probably want wake-up in lock screen checked, and which-ever way "Show body of message" is set now, try the other setting. Otherwise, play around with the options and see what happens.
    tony477g likes this.
    07-14-2013 09:13 PM
  1. Replies: 10
    Last Post: 07-18-2013, 09:32 PM
  2. What happened to my S3?
    By TheJustPull in forum Verizon Galaxy S III
    Last Post: 07-15-2013, 01:54 PM
  3. What techies think still influences "The average user"
    By Rule9 in forum General News & Discussion
    Last Post: 07-14-2013, 11:24 PM
  4. How much total space do u have after the update?
    By smooth4lyfe in forum Samsung Galaxy S4
    Last Post: 07-14-2013, 04:31 AM
  5. iHeartAuto Fans and Car Stereo That Works Well With It?
    By jtdunc in forum Samsung Galaxy S4
    Last Post: 07-13-2013, 06:27 PM
