1. Neven Szary's Avatar
    So I've been poking around online, but haven't really found a solid solution to my problem.
    I connected my phone to my car's bluetooth. I can answer phone calls perfectly fine, but if I want to place a phone call, the only way to do so is if I turn my phone's screen on and navigate to the call/phonebook area. Originally I thought it was due to the lock screen being on, but I've set up a Tasker profile to disable my lock screen while my phone is connected to bluetooth. Does anybody know how I can fix this problem?
    07-25-2013 07:27 PM
  2. GSDer's Avatar
    Sigh - search the forums for "car" and "bluetooth" and you'll have your answer.
    Does your car have the latest bluetooth firmware?
    Have you gone into the audio profile in the car to make sure the correct protocol is enabled?
    Do you have a button or something in the car that's supposed to initiate the voice recognition feature, so that you can do the old "call someone" type of thing?
    Sent from my SCH-I535 using Tapatalk 4 Beta
    07-25-2013 10:08 PM
  1. Netflix audio is only 2-channel stereo, not 5.1 when using Chromecast?
    By Kiersten_Kress in forum Google Chromecast
    Last Post: 08-29-2018, 01:15 AM
  2. Bluetooth Call Audio/Media Audio: Can ONLY select ONE option
    By harryhoudini66 in forum Samsung Galaxy S4
    Last Post: 11-12-2013, 12:58 PM
  3. Wireless Charging the Google Editon S4?
    By planoman in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-13-2013, 05:50 PM
  4. Note: Netflix does NOT require a debit card to use the 3months
    By cammykool in forum Google Chromecast
    Last Post: 07-25-2013, 07:13 PM
  5. Quoting from the Kindle app on the Nexus 7
    By Villordsutch in forum General Help and How To
    Last Post: 07-25-2013, 06:30 PM
