1. pcguys's Avatar
    I'm getting a refurb replacement S3.
    Before I wipe my old phone, what are often overlooked things to do?
    I have the impression it's not as easy as iTunes backup & restore.
    My phone is NOT rooted and the old one is being returned to the carrier and I'm not interested in rooting the old or new one.
    Are they any backup /restore apps that don't require root?
    Are there settings or things I should try to preserve (or at lease screen shot)?
    I used ShareMyApps to generate a list of all the apps on my phone.
    I screen shotted my home screens, and settings for some key apps.
    All my contacts are safetly in gmail.
    I'm not worried about my text messages.
    In Settings | Backup and reset, I checked "backup my data" and "automatic restore". Does this mean that all the settings for all my apps come back?
    I have a dialing widget so I'm going to see if I can by chance copy that folder of data to see if it might preserve my setup.
    I did backup my photos.
    Any other thoughts?
    Many thanks and wish me luck!
    Mike
    07-26-2013 08:52 PM
  2. GSDer's Avatar
    You can try:
    Helium: http://market.android.com/details?id...ikdutta.backup (doesn't require root, but you'll have to install an associated software package on your PC and connect the phone to the PC)
    MyBackup Pro: http://market.android.com/details?id...id.MyBackupPro (there's a trial version)
    You can also try the Kies software on your PC - it works well enough.
    Sent from my SCH-I535 using Tapatalk 4 Beta
    07-26-2013 09:14 PM
  3. pcguys's Avatar
    Thanks, I took a look at helium, installed it, did a backup. Since it doesn't backup the apps, (only their data), I decided to just re-install and reconfigure manually since I really don't want to suck in any bad config that might have been causing me a problem.
    But thanks!
    Mike
    07-28-2013 08:05 AM
  4. meyerweb#CB's Avatar
    Any files you have on the internal SD (photos, videos, music, documents, etc.) should also be copied to either a computer or external SD card to preserve them, and then deleted from the old phone. Be sure to do a factory reset on the old phone before sending it back.
    07-28-2013 08:18 AM
  5. GSDer's Avatar
    By default it only backs up app data, to save space, but all you have to do is uncheck that option.
    Edit: all you have to do to see those options is drag up from the bottom.
    And you could try Cloud Drive: http://market.android.com/details?id...uddrive.photos for your pictures/videos.
    07-28-2013 12:28 PM
  6. pcguys's Avatar
    great advice, thank you!
    BTW, I must say it feels soo clean and liberating to wipe a phone and start from scratch, even though I dread doing it. I got 70% stuff back within 1 day and it's running nicely!
    Mike
    07-28-2013 05:26 PM
  1. Questions before making the jump to HTC & Tmo
    By nickf126 in forum T-Mobile HTC One
    Last Post: 08-19-2013, 02:22 PM
  2. Anyone know how to get rid of ongoing notifications?
    By editionfws in forum Samsung Galaxy S3
    Last Post: 08-17-2013, 01:07 PM
  3. Can't get audio onto tv
    By guinnkevinr in forum Google Chromecast
    Last Post: 08-11-2013, 06:39 PM
  4. Is it possible to unlock with 4.1.1?
    By juergen99 in forum ASUS EeePad Transformer Prime
    Last Post: 07-29-2013, 12:26 PM
  5. Failed to root
    By Pink in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 07-29-2013, 01:14 AM
