1. Craig Rogers's Avatar
    Okay, so this is weird. Within the past few days my phone has been having battery issues. When I remove the charger now, it can take up to 20 seconds to detect it's not charging. I pulled the battery, and the percentage went up 12% when I turned it back on without the charger plugged in. I'm thinking this is an actual battery issue, and I should order a new one. I'm just wondering if anyone has a second opinion before I do order a battery (or get one from my carrier's store).
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
    07-30-2013 06:49 PM
  2. Craig Rogers's Avatar
    Update: switching the usb power block seems to have corrected the problem....I was using an apple power brick before. Different voltages maybe? Whatever, as long as I've corrected the problem I'm happy
    unlmtdRW likes this.
    07-30-2013 07:50 PM
  3. meyerweb#CB's Avatar
    I don't know what the exact reason is, but I've seen a number of posts dealing with problems with using an Apple charger.
    07-31-2013 04:54 PM
  1. Any problems with Note 8 after longterm use?
    By Sebofdoom in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 06-15-2014, 02:07 PM
  2. Chromecast bug on certain phones? Razr, Bionic, etc.
    By tatas#AC in forum Google Chromecast
    Last Post: 10-08-2013, 11:09 AM
  3. Replies: 30
    Last Post: 08-04-2013, 03:45 AM
  4. Cache partition clear problem
    By Randy Achord in forum Samsung Galaxy S4
    Last Post: 07-30-2013, 07:02 PM
  5. VPN, OpenVPN or third party on private phone?
    By mawil1013 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-30-2013, 06:33 PM
