1. samsungash's Avatar
    I have read threads about this but when i try to clear the cache on touch wiz its grey and says 0.
    Shall i clear the data instead?
    It lags in my touch, and freezes. Apps sometimes automatically terminate.
    I think it could be related to the new update.
    I have started deleting a lot of apps. It still does not seem to do anything.
    I notice its a lot more when charging. Or it may be a coincidence.
    How do i do a factory reset without loosing the data on my apps and all my apps?
    08-02-2013 06:31 AM
  2. GSDer's Avatar
    The whole point of a Factory Reset is to wipe everything out and start fresh - you will lose your apps/app data.
    You can take steps to backup/sync your existing data so that it can be easily restored:
    1. Make sure you manually sync your Google account
    2. Use the Kies software on your PC to backup everything (contacts, SMS/MMS, pictures/videos, call logs, etc)
    3. Use Helium: http://market.android.com/details?id...ikdutta.backup to backup your apps and app data
    Edit: you could boot into Recovery mode and clear the cache. Or clear the data for TouchWiz.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4 Beta
    08-02-2013 08:22 AM
  1. Replies: 2
    Last Post: 09-30-2013, 11:30 PM
  2. Samsung Galaxy 4.0, 5.0 - no subforum for this device?
    By Laughter On Water in forum New to the Forums? Introduce Yourself Here!
    Last Post: 08-02-2013, 01:35 PM
  3. Replies: 2
    Last Post: 08-01-2013, 10:35 PM
  4. Samsung Link (Replacing Allshare)
    By torgotorgo in forum Samsung Galaxy S4
    Last Post: 08-01-2013, 12:56 PM
  5. samsung note 2 gets very hot while playing game
    By sereney7 in forum Samsung Galaxy Note 2
    Last Post: 08-01-2013, 11:38 AM
