1. wag101's Avatar
    When I connect my new Verizon Galaxy S3 to my PC filemanager (Win7), I cannot see the photos. Filemanager only displays the name of the picture, type and size information. I only see an icon. Since the file name is only a number assigned by the camera, and no date, I can't find my new photos to download. The phone just did an update to some files that didn't help.
    08-06-2013 09:19 AM
  2. GSDer's Avatar
    Unfortunately this is normal behavior - if you want to see thumbnails, copy all of the photos to a temporary directory on your PC and that will automatically happen.
    Sorry, there's no way around it - Google dropped support for that older connection method.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-06-2013 02:33 PM
  3. wag101's Avatar
    Thanks for the info. That sucks! I wonder what problems that solved for Google?
    08-06-2013 02:43 PM
  4. GTWalling's Avatar
    You can also download AirDroid from Google Play and use the browser of choice to download certain pictures. AirDroid will let you see the pictures within the browser so you can just select the option ones you want.
    08-06-2013 05:44 PM
  5. wag101's Avatar
    Thanks. I'll give it it try.
    08-07-2013 05:58 AM
  1. Free keyboard with stylus Support
    By woox997 in forum Samsung Galaxy Note 2
    Last Post: 08-06-2013, 12:42 PM
  2. 2 slot USB car charger compatible with the Xperia Z
    By schan1988 in forum Sony Xperia Z
    Last Post: 08-06-2013, 09:20 AM
  3. case for s4 with Zens backplate?
    By Whereupon in forum Samsung Galaxy S4
    Last Post: 08-06-2013, 07:02 AM
  4. ANIMATION STUTTER and CHARGING PROBLEM
    By rokholum in forum Legacy Android & Other OS's
    Last Post: 08-06-2013, 05:14 AM
