1. AsapAvi's Avatar
    When I was rooting my samsung galaxy device I followed all the instructions carefully and everything went right. When the phone turned on it was really slow and all these error messages came up like
    "unfortunately, the process.android.media has stopped", "unfortunately, TouchWiz Home has stopped" ect. I would like to know how to unroot my phone and make everything how it was before. PLEASE I need to figure this out by today.
    08-12-2013 02:58 PM
  2. GSDer's Avatar
    The first thing we need to know is what model/carrier your phone is.
    Then, if you can post a link to the steps you followed to root.
    Probably the safest way to return to stock would be to use the Kies software on your PC. It'll prompt you for the model number and IMEI (both listed under the battery) and it'll take care of selecting the correct firmware for your phone.
    If your phone is (somewhat) working you may even be able to use Kies to backup your information before reloading the firmware.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-12-2013 03:16 PM
  3. AsapAvi's Avatar
    Fido and it's I747M
    This is the root I did
    I did a factory reset and it works but the supersu is still there I don't know if it will do the same thing later on should I still do the kies thing ?
    08-12-2013 03:25 PM
  1. HTC voicemail and text help.
    By Viva Terlingua in forum HTC One M7
    Last Post: 08-12-2013, 03:32 PM
  2. HTC One S : guys i really need your help im in deep ****
    By ItsChaii_28 in forum General Help and How To
    Last Post: 08-12-2013, 01:58 PM
  3. Need help with rooting
    By AsapAvi in forum Samsung Galaxy SIII I9300
    Last Post: 08-12-2013, 12:56 PM
  4. Can not make calls from cloned GT-19300 phone please help
    By pocrel in forum General Help and How To
    Last Post: 08-12-2013, 12:29 PM
  5. Re-root from device?
    By Jeffrey99 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 08-12-2013, 10:43 AM
