1. tony477g's Avatar
    Ever since i got the phone the keyboard takes ages to come up. Doesnt matter what app, texting, youtube, google etc it takes at least 10 seconds to come up, not sure what to do at this point. Ive tried stock, swiftkey and swype and they all come up slow
    08-15-2013 01:19 AM
  2. oridimant's Avatar
    Whats your phone? Android ver?
    Sent from my GT-I9300 using Tapatalk 4
    08-15-2013 01:24 AM
  3. keyzlife's Avatar
    I agree that it's bad. I've been on android for a while so I'm used to it, but a lot of people coming from iPhones think it takes forever.
    sent from my T-Mobile Galaxy S4 with Tapatalk 4
    08-15-2013 09:12 AM
  4. keyzlife's Avatar
    Although I will say with Swype or the Google keyboard it's pretty quick. The Samsung keyboard seems to lag more.
    08-15-2013 09:14 AM
  5. GSDer's Avatar
    Did you get the phone new? This is very strange behavior - why didn't you get it looked at when it was still in the exchange period?
    Your best bet would be to backup your information (using Kies or some other solution) and perform a Factory Reset.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-15-2013 10:51 AM
  6. Golfdriver97's Avatar
    Do you have the 'smart' features on?
    Sent from a SlimROM S3.
    08-15-2013 11:10 AM
  7. tony477g's Avatar
    how do I check that? Verizon 32gb s3 bought in October with the latest jelly bean update
    08-15-2013 12:03 PM
  8. tony477g's Avatar
    It happenes randomly, it's not always, whenever a new update would come out it'd go away for a week then progressively get worse. When I first got swiftkey it was quick at first then went to really slow again. I still have warranty on the phone because they talked me into it but verizon doesn't carry the s3 in 32 gb's anymore
    - - - Updated - - -
    Wha'tre the smart features??
    08-15-2013 12:06 PM
  9. tony477g's Avatar
    My other problem is my power/unlock button is going out. I have to push it in just the right spot or else the screen turns back on right after I i turned it on, or it wont turn off and will just go on the turn off screen and start blinking that
    08-15-2013 12:10 PM
  10. Golfdriver97's Avatar
    - - - Updated - - -
    Like the smart stay, smart rotate...that stuff might delay the keyboard.
    08-15-2013 12:10 PM
  11. GSDer's Avatar
    Settings -> About phone will show you the particulars for your firmwaretakes a century for phone keyboard to come up, help!!!-uploadfromtaptalk1376586864669.jpgSince we've now established that it did work correctly and degraded over time, you should boot into Recovery mode and clear the cache and see if that helps.
    08-15-2013 12:19 PM
  12. tony477g's Avatar
    I have all that stuff turned off.
    08-15-2013 02:16 PM
  13. tony477g's Avatar
    Settings -> About phone will show you the particulars for your firmwareClick image for larger version.
ID:	76649Since we've now established that it did work correctly and degraded over time, you should boot into Recovery mode and clear the cache and see if that helps.
    mine shows the exact same as yours how do i go into recovery mode and clear cache?
    08-15-2013 02:18 PM
  14. Golfdriver97's Avatar
    Here is how: http://forums.androidcentral.com/sam...2-s3-tab2.html
    08-15-2013 07:45 PM
  15. tony477g's Avatar
    Will i lose anything if i do this?
    08-15-2013 08:19 PM
  16. Golfdriver97's Avatar
    Nope.
    08-15-2013 08:24 PM
  1. Replies: 3
    Last Post: 08-16-2013, 06:33 AM
  2. Updating rooted gs3 from 4.1.1 to 4.1.2
    By guitarplayer06 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 08-15-2013, 09:45 AM
  3. How to go back to the original factory image?
    By hooni in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 08-15-2013, 07:02 AM
  4. How to remove a corrupted game
    By valpez1 in forum LG Optimus Series
    Last Post: 08-15-2013, 02:49 AM
