1. Calvin Retterath's Avatar
    For about the past 3 weeks I have been experiencing pretty extreme battery drain on my Galaxy S3 usually going down 1% every 60 seconds to a 1:30 when using it only giving the battery about a few hour use, I have done a factory reset and bought a new battery as well as disable google applications that have been known to drain the battery as well as location services. I have downloaded advance task killer and battery drain analyzer and still can't figure out the problem. Anyone have any ideas? Will include pictures
    Attached Thumbnails Galaxy S3 battery drain-screenshot_2013-08-18-21-53-16.png   Galaxy S3 battery drain-screenshot_2013-08-18-21-53-20.png   Galaxy S3 battery drain-screenshot_2013-08-18-22-07-24.png   Galaxy S3 battery drain-screenshot_2013-08-18-22-07-34.png
    08-18-2013 10:09 PM
  2. Jeremy_Collinsworth's Avatar
    14 hours on battery? That's better than I get! The phone is fine, that's normal
    Sent from my SAMSUNG-SGH-I747 using AC Forums mobile app
    08-18-2013 10:50 PM
  3. Calvin Retterath's Avatar
    Really? I really did not use it much at all today because it has been draining a lot lately
    08-18-2013 11:26 PM
  4. Jeremy_Collinsworth's Avatar
    Yeah everything looks fine, my percentage (heavy user) goes down about one every 4 minutes and I have brightness all the way up. Then again, I'm not stock. Still, getting 14 hours out of a battery is pretty good. If you use the phone a lot with the screen on, it's gonna drain a lot faster. That's just the way it works.
    08-19-2013 09:37 AM
  5. tat21985's Avatar
    One thing I am noticing is the color of your mobile network signal.. While you did maintain signal, it was tan for most of the displayed day.. If you live in a fringe area, or if they are doing work on a tower in your area, this will be the norm.. The best scenario would be to have a solid green line in that area, but you can only do so much.. I agree 14 hours is excellent, by power of extrapolation, with you being down to 44%, you would theoretically be able to get about 27 hours on one charge, if this use is typical..
    08-19-2013 10:39 AM
  6. Calvin Retterath's Avatar
    ok thanks alot guys for the help
    08-19-2013 11:17 AM
  1. Got replacement S3 - 4G not staying connected!
    By shley00 in forum Verizon Galaxy S III
    Last Post: 02-08-2014, 08:47 PM
  2. Bell Galaxy S3 just.. died.
    By Go Easy Jerk in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 10-02-2013, 08:25 PM
  3. Android OS Battery drain?
    By Rcrdude64 in forum Sprint Galaxy Note 2
    Last Post: 08-24-2013, 11:03 PM
  4. Galaxy S3 just.. died
    Last Post: 08-23-2013, 05:23 PM
  5. Battery Usage
    By DeepSeaGoddess in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-19-2013, 06:58 AM
