1. cycy15's Avatar
    I have a Galaxy s3 and it has recently been having issues. When ever i listen to music on my phone, about 15-20 minutes later all my songs are gone, but when i restart my phone, clear data, or disable media storage they come back. This has been going on for a while and its pissing me off. please help, thanks.
    08-19-2013 02:37 PM
  2. cycy15's Avatar
    Please guys, this is really bothering me!
    08-19-2013 06:33 PM
  3. GSDer's Avatar
    You haven't really provided much information:
    - is the music stored on the internal memory or an SDCard?
    - what app(s) are you using to play the music?
    - what's the source of the music (files you dragged over; Amazon Music Store; other)?
    - what do you mean when you say they "disappear":
    -- if you use a File Manager, can you find the files?
    -- what about other files on the same storage media?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-19-2013 07:56 PM
  4. cycy15's Avatar
    -The music is stored on both the SD card and memory card (half of the songs are on one and the other half are on the other)
    -im using a normal music player widget that came with the phone
    -Im getting all my songs from a music downloader app
    -For example, when im listening to music, it randomly pauses and i go see what happened, and it says "no songs" and a little notification saying songs arent supported
    -I have file manager but i dont know what to look for
    08-19-2013 09:14 PM
  5. GSDer's Avatar
    I'm going to go out on a limb and suggest that you unmount the SDCard from the phone and remove it, and then try playing only the music that's on the internal storage and see what happens. If that works correctly, well, the next question would be - is it a SanDisk SDCard?
    08-20-2013 04:06 AM
  6. cycy15's Avatar
    Nope, diddn't work
    08-20-2013 11:59 PM
  7. GSDer's Avatar
    When your music is working correctly, if you use the My Files app, can you find the music on the internal memory? Look hereNeed help with music player/media storage-uploadfromtaptalk1377061437518.jpgthen hereNeed help with music player/media storage-uploadfromtaptalk1377061469720.jpg(I don't happen to have any music stored locally.)
    If you can find the music, go ahead and reproduce the problem and then use the My Files app to look for the files in the same place. Let me know what happens.
    08-21-2013 01:07 AM
  8. cycy15's Avatar
    All the songs are located in:
    /storage/extSdCard
    I had them on the sdcard but that didnt work either.
    08-21-2013 01:41 AM
  9. cycy15's Avatar
    Please Guys, its like I cant even listen to music anymore.
    08-23-2013 12:09 AM
  10. Umnik192's Avatar
    It looks like your player app is trash
    Try another music player app and check. For example rocket player, n7 player or Astro Player.
    08-28-2013 05:19 AM
  11. GSDer's Avatar
    All the songs are located in: /storage/extSdCard
    That location IS the SDCard. As noted earlier, you should move some music to the internal memory (/storage/sdcard0/music) then remove the SDCard completely and try again.
    If the songs stop playing, use the My Files app to look for them.
    08-28-2013 12:05 PM
  1. Nexus 7 with Sky email problem
    By Solum in forum New to the Forums? Introduce Yourself Here!
    Last Post: 08-21-2013, 09:25 AM
  2. Lag issues with Samsung Galaxy S4?
    By bmx1500 in forum Samsung Galaxy S4
    Last Post: 08-20-2013, 09:47 AM
  3. Help please!
    By jonboy88 in forum General Help and How To
    Last Post: 08-19-2013, 05:07 PM
  4. Firmware upgrade encountered an issue?!?!HELP FAST
    By Suey Chu in forum General Help and How To
    Last Post: 08-19-2013, 01:39 PM
