1. nicmg's Avatar
    Hi there,
    I am having problems with clearing my defaults for texting, calling etc... when i press call a contact, it shows up complete action with call/skype and sends me to app manager, i go to all in app manager and select call and skype and clear defaults but it is still not working. I have also tried to reset app preferences but this also does not work, can anyone enlighten me?
    08-21-2013 05:49 AM
  2. meyerweb#CB's Avatar
    In app manager, tap the menu button, then Reset app preferences. This will eliminate all your app defaults, so those you want to have defaults you'll have to reset as you use them.
    08-21-2013 09:27 AM
  3. GSDer's Avatar
    When you try to send an SMS/MMS is it also showing Skype in the "Complete action" dialog?
    If I understand correctly, when you pick an action, instead of taking you to that action it's actually taking you to the Application manager?
    Have you tried uninstalling Skype just to see if it fixes your problems with defaults?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-21-2013 12:06 PM
  4. italiansoxgirl25's Avatar
    didn't work. still having that annoying message" clear default settings
    11-26-2013 07:35 PM
  1. Android File Transfer on MacBook
    By SiBlackwell in forum Samsung Galaxy S4 Mini
    Last Post: 08-22-2013, 03:04 AM
  2. s3 no screan-How to copy contacts?
    By 9A6DQB in forum Samsung Galaxy S3
    Last Post: 08-21-2013, 02:30 PM
  3. How to desable the speaker on Galaxy S3
    By Robert L1 in forum Samsung Galaxy SIII I9300
    Last Post: 08-21-2013, 05:21 AM
  4. Problems uploading pictures to Twitter
    By Paddy1138 in forum Samsung Galaxy S3
    Last Post: 08-21-2013, 04:35 AM
