1. Mike Coetzee's Avatar
    My S3 was rebooted but after entering the pin it will only allow emergency calls. If i put the sim in a S4 it works fine. Any solutions please?
    08-26-2013 02:38 AM
  2. GSDer's Avatar
    Sounds to me like it's not recognizing your PIN - is it actually letting you into the full phone UI? If so, it's possible that something is wrong with the SIM slot. You could shut it down, pull the battery and blow it out with compressed air. Try inserting/removing the SIM a few times.
    At worst, stop in to your local carrier and get THEM to put another SIM in and see what happens.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
    08-26-2013 03:46 PM
  1. Replies: 3
    Last Post: 08-23-2014, 06:39 PM
  2. Headphone Jack (audio problem)
    By tyreesharenae in forum HTC EVO 3D
    Last Post: 08-28-2013, 03:02 AM
  3. Having problems rooting Samsung Conquer 4G
    By jetskid420 in forum Samsung Conquer 4G
    Last Post: 08-26-2013, 07:26 PM
  4. Text tone problem?
    By kurpaige in forum Motorola Droid MAXX
    Last Post: 08-26-2013, 10:35 AM
  5. Viber reverts calls from bluetooth headset to the handset on Droid Razr HD Maxx!
    By mashardy in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-25-2013, 11:11 PM
