1. papafrankm's Avatar
    Have had my phone since July rollout.
    It seems my original battery, is losing longevity. Luckily I purchased a charger with battery.
    Is anyone else experiencing end of life for 1 year batteries.
    08-26-2013 05:54 PM
  2. meyerweb#CB's Avatar
    I think it depends a lot on how heavily your phone gets used, and how often the battery discharges deeply and is recharged. These batteries have a certain number of charge cycles before they start to lose capacity, so the more often they're fully discharged the faster they'll start to fade. To maximize battery life, don't let the battery get below 25%. Frequent short charges, to keep it above 50%, are better than letting the batter discharge fully.
    Heat is also the enemy of batteries. Fast charging generates a lot of heat. Charging off the stock 700mA charger, or a USB port, is better for the battery that a high amperage rapid charger. Running apps that heat the phone up (like using GPS for long periods, and especially using GPS while charging) will shorten battery life, too.
    In the end, just be glad you have an interchangeable battery and can get an inexpensive replacement. Just think how the htc One owners are going to feel when their batteries start fading.
    08-26-2013 09:50 PM
  3. papafrankm's Avatar
    Thanks for informative reply.
    08-27-2013 06:16 AM
  1. S4 shuts down by itself, battery drain
    By nashZx in forum Samsung Galaxy S4
    Last Post: 10-13-2013, 07:12 PM
  2. 48 Hour Battery Life Test
    By p08757 in forum Motorola Droid MAXX
    Last Post: 08-29-2013, 06:57 PM
  3. More battery life and glitch problems
    By nosky92 in forum Droid RAZR MAXX HD
    Last Post: 08-29-2013, 03:44 PM
  4. 2 small questions regarding battery and network.
    By John Beirne in forum Google Nexus 4
    Last Post: 08-28-2013, 02:51 AM
  5. Command Center effect on Battery?
    By Eclipse2K in forum Motorola Droid MAXX
    Last Post: 08-26-2013, 02:46 PM
