1. Beth Reim's Avatar
    My galaxys3 has charged fine on the charger it came with and others like it up until recently. Now the only charger it works with is one that was for an old lg phone that is not a USB. Any charger that that has/ is a USB cable won't charge the phone completely and does it very slowly, like 24 hours to get to a full charge slowly. Does anyone know any way to fix this?
    09-02-2013 01:24 PM
  2. josiahlikesminecraft's Avatar
    It may be your battery or a problem with your charging port.
    Posted via Samsung S3
    Beth Reim likes this.
    09-02-2013 01:28 PM
  3. meyerweb#CB's Avatar
    Dude, if the battery charges normally with some chargers the problem isn't the battery itself. Stop spamming the forums with your battery ads.
    To the OP, do the chargers that fail to work properly each have a different USB cable, or are you using the same USB cable with both? If you're using the same cable, it's probably bad.
    If they each have their own cable, try charging the phone from a computer's USB port with each cable. (don't use a USB hub; plug it directly into a port on the computer). If it charges OK, then your other chargers are bad.
    09-09-2013 09:20 PM
  1. Replies: 2
    Last Post: 10-09-2013, 06:39 AM
  2. remove ringtone for certain contacts?
    By TTuck10 in forum Verizon HTC One
    Last Post: 09-11-2013, 08:11 PM
  3. Google+ on my lock screen, how do I get rid of it?
    By lukas100lukas in forum Legacy Android & Other OS's
    Last Post: 09-04-2013, 07:34 PM
  4. 4glte icon still present when on wifi??
    By wpnokia920 in forum Motorola Droid MAXX
    Last Post: 09-02-2013, 01:51 PM
  5. Changing picture resolution for email on DNA
    By Cigar_Maverick in forum Verizon Droid DNA
    Last Post: 09-02-2013, 11:46 AM
