1. Dave Hessels's Avatar
    Hey Guys,
    S3 user looking for some help.
    All my contact's phone numbers have seem to have dissapeared. When looking at my FULL contact list, all I see is the names of the people, and that they are linked to my Whatsapp account(for example), but when I open the contacts, the numbers are gone.....
    This just happened to me, I didnt upgrade anything, I didnt import or export anything....or whatever....
    I have tried multiple resets, and upgraded my S3's Software.....
    Anyone?
    09-19-2013 06:34 AM
  2. kylie brown's Avatar
    Ummmm, don't know but I think a soft reset would just make everything fine you may try doing that from your settings menu.
    Dave Hessels likes this.
    09-19-2013 07:23 AM
  3. DroidArmy's Avatar
    Reload the contracts? Are they saved on your google account?
    09-19-2013 09:16 AM
  4. Dave Hessels's Avatar
    Nah, I dont have anything saved there :-(
    - - - Updated - - -
    Trying now. Thanks!
    09-19-2013 09:17 AM
  5. GSDer's Avatar
    It sounds like WhatsApp hijacked your contacts data; if I'm not mistaken there was just an update to WhatsApp.
    In the future, if you don't want to sync your data with Google, you can use the Kies software on your phone to backup your contacts, SMS/MMS, call logs, pictures/videos, etc.
    There are also apps like Helium: http://market.android.com/details?id...ikdutta.backup (free; works on non-rooted phones) that will backup your contacts, SMS (no MMS and apps and app data.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    09-19-2013 09:41 AM
  6. ragz_mln's Avatar
    Open the contacts app, click on menu key, select merge with Google, select the google account you want to merge with, and you're done. Note-you can only merge all your contacts, can't do selective merging.
    09-27-2013 11:15 PM
  1. Contacts slow to appear on my Samsung Galaxy s4 mini
    By selimlok in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-20-2015, 01:28 PM
  2. play store search function have problem
    By micheal datoc in forum General Help and How To
    Last Post: 09-23-2013, 09:55 AM
  3. s3 root no pc
    By Jessie Upchurch in forum Verizon Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 09-19-2013, 03:30 AM
