1. agusiek's Avatar
    My GS3 wont turn on! When i try to turn it on, It goes to the o2 logo with bubbles, then to the samsung logo bit then vibrates and back to the o2 logo, and i dint know what to do! Please help?
    09-21-2013 02:33 AM
  2. agusiek's Avatar
    Is it modified in anyway, as in rooted, flash etc?
    Its not rooted
    09-21-2013 02:49 AM
  3. GSDer's Avatar
    1. Have you tried taking the battery out for a minute, replacing it, then powering on?
    2. Are you sure the battery is well charged? Take the battery out, replace it, and then plug in the charger (without pressing the Power button) - after a moment you should see a battery graphic on the screen showing the level of charge.
    3. Try booting into Recovery mode - with the phone completely off (ala battery pull), press and hold the Volume Up and Home and Power buttons simultaneously, and release them all when you see the Samsung splash screen.
    If this takes you to the Recovery menu, select "Clear cache" (use the Volume rockers to navigate the UI and the Power button to select), then restart.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    09-21-2013 09:52 AM
  4. agusiek's Avatar
    I did all of those, still not working. The first thing i actually did was take the battery and charge it and everythjng but thanks anyway
    09-24-2013 11:01 AM
  5. GSDer's Avatar
    If you can't boot into Recovery mode perhaps you can boot into Download mode: with the phone completely off, press and hold the Volume Down and Home and Power buttons simultaneously, and release them all when you see the O2 splash screen.
    If this works let us know and we'll tell you how to reload the firmware.
    09-24-2013 02:51 PM
  1. help!!!
    By Dallasgirl2392 in forum Google Nexus 4
    Last Post: 09-21-2013, 12:05 PM
  2. i've format my nexus 4 please help me!
    By siaaldo in forum Google Nexus 4
    Last Post: 09-21-2013, 10:08 AM
  3. Help which MicroSD is better~
    By FrostbiteQ in forum General Android Device Chat
    Last Post: 09-21-2013, 09:06 AM
  4. Why is my data not working? Help!!
    By katiegorka in forum myTouch 4G Rooting, ROMs, and Hacks
    Last Post: 09-21-2013, 06:14 AM
