1. Jamie Moseley's Avatar
    I plugged my phone in last night when I went to bed and now it wont turn on I have tried taking the battery out, tried plugging it in with a different charger I have tried the reset and nothing happens please help.
    09-22-2013 09:49 AM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    Can you try a different battery?
    09-22-2013 09:53 AM
  3. GSDer's Avatar
    If the phone is completely off and you connect a charger, you should see a battery graphic on the screen (and perhaps a red LED). Do you get that?
    If not, leave the battery out for 5 minutes, put it back in and (without trying to turn it on) connect a charger. Do you get the battery graphic?
    If all else fails, take the battery out, connect the charger and try turning it on.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    Golfdriver97 likes this.
    09-22-2013 09:58 AM
  4. Golfdriver97's Avatar
    Good ideas from GSDer.
    Sent from a Slim 4.3 S3
    09-22-2013 11:17 AM
  1. HELP! Can't access music files on N4
    By BristolOReilly in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 09-28-2013, 12:09 AM
  2. (help)I cannot uninstall software~
    By fgbdghgdn in forum General News & Discussion
    Last Post: 09-24-2013, 10:16 PM
  3. Galaxy S3 screen wont light up..Help!
    By KN_2989 in forum Samsung Galaxy S3
    Last Post: 09-22-2013, 07:38 PM
  4. Instagram app wont work! please help
    By fantom555 in forum Android Apps
    Last Post: 09-22-2013, 12:11 PM
  5. Please Help Me To Fix My Phone :(
    By Halmy Afrial Khozaldy in forum Samsung Galaxy Ace
    Last Post: 09-22-2013, 10:02 AM
