1. Darren Lumpkins's Avatar
    Every once in awhile ill get a ill go to open my texts and it says I don't have any. Ill reboot and the texts shows up again..then few days later it will do the same thing. This is with the stock messaging app and I have used other texting apps and same issue. How can I fix this
    09-24-2013 07:50 AM
  2. GSDer's Avatar
    That's not much to go on.
    What model/carrier/firmware version?
    When did the problem start? Anything installed/updated around the same time?
    What have you already tried to fix the problem?
    Ready for a Factory Reset (i.e. have a recent backup)?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    09-24-2013 03:21 PM
  1. keyboard and texting
    By AllUserNamesTakenX3 in forum Verizon LG G2
    Last Post: 09-24-2013, 01:41 PM
  2. restoring text messages on 4.2.2
    By azibiz in forum HTC One X
    Last Post: 09-24-2013, 07:43 AM
