1. caslad66's Avatar
    My daughter recently got a Samsung Tab 2 10.1 unfortunately Sky havent sorted the Sky Go app to work on this device.
    However she can access it on her S3 phone. Question is....how does she tether the two devices to be able to see Sky Go on the larger Tab 2 screen
    Howard
    10-04-2013 11:25 AM
  2. GSDer's Avatar
    I couldn't find a Sky Go app in the Google Play Store - can you provide a link?
    Seems like this TV watching service should be accessible via a browser - why doesn't she just use a browser on the Tab 2?
    Typically you'd use a Chromecast or AllShare Cast setup to mirror content on a TV, but I'm not familiar with a solution that allows you to mirror the S3 display on another Android device - sorry.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-04-2013 03:31 PM
  3. caslad66's Avatar
    As I said before SkyGo doesn't support Galaxy Tab 2 10.1
    10-05-2013 07:08 AM
  4. GSDer's Avatar
    What you said was that the Sky Go app wasn't supported, and what I asked is why she doesn't just use a browser - a browser is a browser, regardless of platform.
    In any case, I have not seen a solution that allows you to mirror the S3 display on another Android device. She can purchase an MHL<>HDMI adapter and mirror the display on a TV, or see if Chromecast via a browser on the S3 will work.
    10-05-2013 04:23 PM
  5. caslad66's Avatar
    Tried the browser approach first.SkyGo page simply ask you to download appropriate app for your device be it pc tablet or phone
    10-06-2013 03:44 AM
  6. GSDer's Avatar
    Thanks for the clarification.
    If that's the case, I don't see any alternatives other than: wait for the app to add support for her tablet; get a supported tablet; use a TV to mirror the S3 display; root the tablet and change the build.prop to make the device seem like an S3 (or other supported device).
    10-06-2013 10:07 AM
  1. Using Google Docs/Drive/Keep on Note 3 (Are you disappointed?)
    By AgentScribe in forum Samsung Galaxy Note 3
    Last Post: 10-16-2013, 09:43 PM
  2. Looking for a way to use a new SD Micro in my Android
    By Robert Burns4 in forum General Help and How To
    Last Post: 10-06-2013, 01:38 PM
  3. Replies: 5
    Last Post: 10-04-2013, 12:09 PM
  4. Galaxy Note 3 - How low will prices go, do you think?
    By purpledog10 in forum Samsung Galaxy Note 3
    Last Post: 10-04-2013, 11:06 AM
  5. Tethering works on laptop, but my phone can't go online?
    By se1ene in forum General Help and How To
    Last Post: 10-04-2013, 08:48 AM
