1. dawitm's Avatar
    I installed Viber on my Galaxy S3 but i can't make any call and it says viber has got crashed. Is there any setting that i missed in my phone?
    10-19-2013 01:16 AM
  2. GSDer's Avatar
    Hard to say. Did you already get an activation code?
    I haven't used it myself but I thought I saw some mention of having to approve the app as a Device administrator.
    You could go to Settings -> Application manager -> Viber and clear cache; if your problem isn't resolved then go back in and clear data.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-19-2013 02:21 AM
  3. Viber's Avatar
    Hi,
    I'm an official rep. from Viber. I'm here to help
    First, please make sure that you have the latest version of Viber installed.
    Also, if you are using a Custom ROM - do you know whether or not Viber worked when your phone was on Stock ROM?
    If the problem still persists, then we would appreciate if you could take a minute and report the details to our support team using this direct link: Your ticket details
    When you submit the ticket, in the line called: "Through which channel did you submit your initial inquiry", please make sure to choose "Technical Forum". With this information, our development team will hopefully be able to find the source of the problem, and ultimately resolve it.
    Thanks in advance
    10-20-2013 05:57 AM
  4. Rahman Zarook's Avatar
    viber shows error when i touch continue button on my device
    07-05-2015 09:50 PM
  5. Rahman Zarook's Avatar
    yes i got the code then it was k but later it was showing error
    07-05-2015 09:54 PM
  1. Replies: 17
    Last Post: 02-03-2017, 01:06 PM
  2. S4 to nexus 5
    By Flashheatmvp3 in forum Samsung Galaxy S4
    Last Post: 11-08-2013, 09:28 AM
  3. How to install apps to SD card
    By jonlien in forum Samsung Galaxy Note 3
    Last Post: 10-20-2013, 07:56 PM
  4. ISSUE: Netflix app crashes at bootup
    By Dolfan058 in forum Android Apps
    Last Post: 10-19-2013, 03:09 PM
  5. Major Charging Problems
    By stryder36x in forum Google Nexus 7 Tablet (2012)
    Last Post: 10-19-2013, 09:47 AM
