1. Tim Ross1's Avatar
    Hey my s3's wifi doesn't work without mobile reception it seems, was just wondering if that's supposed to happen? I have poor reception around my house and whenever my phone can't find any reception the wifi doesn't work. It says it's connected under Settings but webpages won't load and I can't access anything online. I've found I can fix it by turning on flight mode and turning the wifi back on, but then it always stops working again after a couple minutes. Anyone have any idea what's going on?
    Cheers
    10-20-2013 06:05 AM
  2. GSDer's Avatar
    No, that's not supposed to happen - Wi-Fi should work anytime there's a decent signal and you have the correct authentication.
    I'd suggest going into your router and reconfiguring the security to be Open (i.e. no security - this is just a temporary measure). Then delete the connection on the phone and re-add it and see if the phone successfully connects. If it does then something was squirrelly with your router configuration.
    Have you tried using Wi-Fi anywhere else?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-20-2013 07:52 PM
  1. Galaxy S3 screen time out not working
    By amy1503 in forum Samsung Galaxy S3
    Last Post: 05-11-2015, 02:26 AM
  2. Samsung Galaxy Ace - Incoming Message: Memory Full- Help!
    By amy1503 in forum Samsung Galaxy Ace
    Last Post: 01-24-2014, 07:52 AM
  3. Samsung GS4 unsupported files/videos
    By Kaner182 in forum Samsung Galaxy S4
    Last Post: 10-21-2013, 08:11 AM
  4. Sprint Samsung Galaxy Note 3 - Amazon.com $249.99 and they matched it!!!
    By garyg_nh in forum Sprint Samsung Galaxy Note 3
    Last Post: 10-21-2013, 07:46 AM
  5. AT&T Galaxy Note - Internet problm !
    By JohnHellis in forum AT&T Galaxy Note
    Last Post: 10-20-2013, 08:06 AM
