1. Klaus_K's Avatar
    Hi, this is a problem I've had a few times recently running android 4.1.2 on my galaxy s3. I set the alarm, make sure sound is on and the day is activated (I.e. it says alarm is due in 8 hours or so). Despite this, when the alarm becomes due, no sound is produced.
    Luckily my wife has spotted the problem and woken me and my alarm shows it is snoozing. AFAIK I haven't changed anything on my phone. I do have "swipe" lock enabled, but this didn't cause any problems in the past.
    10-23-2013 06:39 PM
  2. LEMONGRAB's Avatar
    I have the same problem with countdown timer randomly not going off. Very frustating while baking or proofing.
    SSgS|||_2_DroidCentral
    10-24-2013 12:46 AM
  3. GSDer's Avatar
    So the alarm (forget the audio issue for the moment) isn't being triggered, or it's being triggered (not making any audio that you're aware of) and then going into snooze mode?
    Have you checked the audio that the alarm app defaults to? Perhaps you should pick a different tone just to see what happens?
    Does the alarm app have its own volume settings or does it use the system default?
    You can try Alarm: http://market.android.com/details?id...ist.alarmClock - this thing hasn't let me down.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    10-24-2013 12:48 AM
  1. Sound/Volume level resetting?
    By freestylee30 in forum Samsung Galaxy Note 3
    Last Post: 04-25-2015, 11:39 AM
  2. Replies: 1
    Last Post: 10-23-2013, 10:31 AM
  3. Alarm clock works when phone is powered down.
    By k91191 in forum HTC One M7
    Last Post: 10-23-2013, 07:51 AM
  4. Alarm that by-passes headphones
    By timpsummers in forum Android Apps
    Last Post: 10-22-2013, 11:19 PM
  5. strange no call sound issue
    By forester0 in forum Samsung Galaxy S4
    Last Post: 10-22-2013, 09:37 PM
