1. virtuouskate's Avatar
    I just got a Straight Talk CDMA (Verizon) Samsung Galaxy S3. I'm switching from T-Mobile S3. What's the best way to move as much of my phone as possible from one device to the other? I've looked at Samsung Smart Switch and Kies Air, but what I'm really hoping for, since I'm sticking with the same type of phone, is a way to copy everything, including settings and apps (some of which have locally-saved information I want to keep) from one phone to the next, like the BlackBerry Switch Kit that you can download to your computer. Unfortunately, the phones aren't both running the same version of Android--both are Jelly Bean, but I installed the 4.3 update on the T-Mobile phone and the other one still has 4.1.2.
    11-23-2013 12:52 PM
  2. Paul627g's Avatar
    Hello,
    You could try using Helium from the Play Store. That seems to do a great job for backing up apps/data.
    11-23-2013 01:10 PM
  1. How to Remove "nexus5" from the screen
    By gm10 in forum Google Nexus 5
    Last Post: 10-30-2015, 01:52 AM
  2. Newbie- Note 10.1 (2014) Stuck on SAMSUNG screen
    By zzznap in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-04-2014, 01:07 AM
  3. After 4.3 upgrade: S3 loses 3g data network
    By Chrisewolf in forum Samsung Galaxy SIII I9300
    Last Post: 12-10-2013, 01:42 AM
  4. Replies: 2
    Last Post: 12-09-2013, 07:47 AM
  5. Replies: 8
    Last Post: 11-24-2013, 03:55 AM
