1. supersowf13's Avatar
    Okay so since i got the phone the vibration has never worked.
    I have been looking all over online searching for ways to solve my problem as i would really prefer vibrate on my phone.
    I have tried the *# codes and they have been unresponsive. I set my phone to Factory reset. I have even Went into Apps Found Media Storage Force stop and Clear data and then went to Google Framework and cleared data and then turned my phone off and back on.
    STILL no vibration. And yes all the vibration options are on/enabled.
    Any one got any other suggestions?
    11-26-2013 02:44 PM
  2. Matt_Zenick's Avatar
    Try and flash a stock rom through Odin then if it still doesn't work then go to the place that supplied you with the phone and ask for a replacement.
    11-26-2013 02:53 PM
  3. supersowf13's Avatar
    Where would i find that/What is that?
    11-26-2013 02:56 PM
  4. Matt_Zenick's Avatar
    What carrier do you have?
    11-26-2013 03:02 PM
  5. supersowf13's Avatar
    Do you mean My mobile providers? That would be Virgin?
    11-26-2013 03:04 PM
  6. Matt_Zenick's Avatar
    Download this and follow the instructions I have in the zip file
    https://www.dropbox.com/sh/3orl5tkbruo1hvh/_vHDU8diaS
    11-26-2013 03:09 PM
  7. supersowf13's Avatar
    Great thank you!
    So i download this, Extract it and put it in my phone when ive connected it to my PC?
    11-26-2013 03:12 PM
  8. Matt_Zenick's Avatar
    After I will have more instructions. First shut down your device, then power on by simultaneously pressing the power button, home button and volume down key. Now you will see download mode and you will be asked if you want to cancel or continue. Press volume up to continue or volume down to cancel and reboot. Then you are in download mode then follow the instructions in the file i gave you
    11-26-2013 03:12 PM
  9. supersowf13's Avatar
    I did this and opted for continue, but it seems to be taking a long while, is this supposed to happen?
    11-26-2013 03:28 PM
  10. GSDer's Avatar
    Whoa! Whoa! Whoa!
    Before we go off half-cocked, how about asking supersowf13 if the phone has ever been modified? Has it been this way since he got it?
    If the phone has never been modded, and it's always been this way, it needs to go back to the carrier for replacement (this should have ideally been done in the 14 day exchange period).
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
    11-26-2013 03:30 PM
  11. supersowf13's Avatar
    Whoa! Whoa! Whoa!
    My first sentence to this thread was indeed my phone was like this since i got it out the box, ive had it was past the 14 day period. Im now incredibly tempted to take the battery out and throw it to the other side of the room and rage! It doesnt help that im impatient, the Download screen is still 'Downloading'
    11-26-2013 03:34 PM
  12. Matt_Zenick's Avatar
    Download it and extract it to your desktop then open odin.exe (run as admin) then extract CWM_6_Non-Touch then open Odin click PDA go to the extracted CWM_6_Non-Touch and click on the file in it put your phone in download mode by simultaneously pressing the power button, home button and volume down key when turning it on then plug it in then on odin hit start once finished put this file on your sd card http://g60madman.vmobi.us/d2vmu/stoc...ockworkmod.zip and then reboot AFTER putting the file on your sd card by holding volume up + home + power then click install zip and find vmgalaxys3-stock-clockworkmod.zip then click on it then hit yes to install then your prob should be fixed
    Attached Thumbnails HELP: Samsung Galaxy s3 Vibration wont work!-screenshot.1.jpg
    11-26-2013 03:34 PM
  13. supersowf13's Avatar
    I give up guys, its clearly my phone being faulty!
    11-26-2013 03:39 PM
  14. Matt_Zenick's Avatar
    Here search youtube on how to get cwm recovery for samsung galaxy s3 then install cwm recovery then put http://g60madman.vmobi.us/d2vmu/stoc...ockworkmod.zip on SD card and boot into cwm recovery by holding volume up + home + power while the phone is off then click install zip and find vmgalaxys3-stock-clockworkmod.zip then click on it then hit yes to install then your prob should be fixed
    11-26-2013 03:48 PM
  1. Samsung hub won't let me in.
    By smalba in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-19-2015, 09:50 AM
  2. e:signature verification failed error help!!!!
    By sunsetcorl in forum Verizon Galaxy Note 2
    Last Post: 08-15-2015, 10:35 AM
  3. Galaxy S4 Google Play edition - official Android 4.4 Kit Kat is rolling out now
    By kgbkny in forum Samsung Galaxy S4 Google Edition
    Last Post: 02-14-2014, 12:57 PM
  4. Galaxy S3 i9305 4.3 update
    By Adam Kinder in forum Samsung Galaxy S3
    Last Post: 11-27-2013, 02:39 PM
  5. plzz help...........
    By Twentyfour Trackz in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-26-2013, 02:30 PM
