1. Madeline Barsky's Avatar
    So after being fully charged overnight my phone randomly turned off. I tried turning it back on but it would only vibrate, have the samsung logo appear, and then turn off again. I tried everything I could to fix it; I tried to hold down the power button, then I tried taking the battery out, then I tried to hold down the home, power, and volume up buttons all at once. After those didn't work I tried to take out my battery for a little, have my phone charge, and then put the battery back in, but nothing worked. Can anyone help me??
    12-03-2013 08:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! How long did you press and hold the Home, Power, and Vol Up buttons? Sometimes you have to keep them all down for a good 5-10 seconds. If you're able to get a response, then follow these instructions to clear the system cache: http://forums.androidcentral.com/sam...2-s3-tab2.html
    Do you have another battery you could try? Batteries sometimes go bad abruptly. Take your battery out, put it on a flat surface, and see if you can spin it freely--if you can, it's bulging in the middle, which means the battery has gone bad.
    12-03-2013 09:36 PM
  3. Madeline Barsky's Avatar
    I've tried holding the buttons down for at least 30 seconds. I will try to see about the battery though. Thanks!
    12-03-2013 09:50 PM
  4. B. Diddy's Avatar
    Another thing to consider is to remove the microSD card first, then try to power on. I've read some reports of corrupt SD cards causing bootup trouble.
    12-03-2013 09:53 PM
  5. Madeline Barsky's Avatar
    would it be possible for me not to have a microSD card? because I couldn't find it when i took off the back of my phone
    12-03-2013 10:13 PM
  6. B. Diddy's Avatar
    Sure, I just thought that if you had a microSD in, it would be worth taking out. You're looking here, right?
    12-03-2013 10:20 PM
  7. Madeline Barsky's Avatar
    yeah i was looking there but no i don't have a card in
    12-03-2013 10:34 PM
  1. Replies: 13
    Last Post: 12-27-2013, 01:24 AM
  2. Replies: 4
    Last Post: 12-25-2013, 02:06 AM
  3. Unlock US Cellular Moto X To Use On GSM
    By Jenny Broady in forum Moto X
    Last Post: 12-19-2013, 02:44 AM
  4. Recovery woes. Need any help at all.
    By Saenkosan in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-04-2013, 08:31 AM
  5. Consumer Cellular APN for Galaxy S4 Mini
    By royp1942 in forum Samsung Galaxy S4 Mini
    Last Post: 12-03-2013, 08:25 PM
