I have a AT&T SGH-I747 and when I go on kies it doesn't read it? (yes I WAS rooted the 4.3 update removed it which kies couldn't read it before and after) help? Thanks!
I must've misunderstood you - I thought you were saying that Kies didn't detect your phone. You're actually saying that Kies detects your phone but says it isn't supported?it says kies doesn't support my phones version
What model/carrier/region, and what firmware did you have on there before you loaded 4.3? You said it was rooted - anything else?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk Pro
Do you still have custom Recovery software (CWM; TWRP) installed?
When you run Kies and connect your phone, what does it show? Can you take a screenshot of the Basic information tab and attach it (don't forget to cover up the phone number)? It should look something like thishttp://img.tapatalk.com/d/13/12/27/u7y2a8y7.jpgalthough this is from Kies v2
It could be - that's why I'm asking for the screenshot of the error.Is CWM the problem? I do have it still installed.
