Greg Riddle
Let's just be clear - myphoneexplorer is not full of malware. During the install process you are offered the option to install or not install a ton of crap you don't actually want, but nothing harmful, and you do have the option not to install it.
However, myphoneexplorer doesn't overcome the problem. It will let you force your outlook contacts to the phone, or vice versa, as an alternative to a full two way sync.
I'm really hoping the update of Kies allows one way sync only. I have separate personal and work PCs and want to keep my outlook contacts separate on the PCs, but have them all on the phone. As long as I only create or change contacts on the PCs this used to work fine with Kies.
