Hi,
I'd been having some trouble with my SGS3 for a while. Well a lot, especially with charging and this ghost data problem where the storage doesn't add up to how much should actually be there.
I had been back and forth, mainly on this forum viewing all the different threads about it but today I finally rooted my phone and used Disk Usage to see where the problem lay, and it was with a huge log file which I managed to delete. You can do it that way, or you can do it the easier way, suggested on another forum which is:
"You don't have to root your phones to fix this problem. Just dial *#9900# on the phone and then select from menu - delete dumpstate/logcat. I tested this solution on my SGS2 and it works. "
Credit to damianoz here
Good luck, and I hope this helps a lot of people.
Cheers,
Liam.
P.S. Do many other people have an issue with the phone turning off (and requiring a battery pull) after you disconnect the charging cable when the battery is full? - I will have a search now as well.
Cheers,
Liam.
