12-25-2018 12:20 PM
81 1234
tools
  1. Saqib Rana's Avatar
    i think i found your problem, in the image shown above your CSC is KSA(Saudi Arabia) but you are from Pakistan
    you need to flash a Pakistan firmware CSC-PAK
    my dear I flashed Pak version of 4.1.2 and 4.3 both. but same problem, I contacted the person who repaired the EMMC chip, he said it's board is modified now so you can not update to official firmware. he can mend it with Z3X box, but asked me not to update to official, only custom roms.
    05-12-2014 08:13 AM
  2. mobilecrackers's Avatar
    Is that guy a Samsung service center staff? Whether Custom rom or official rom they all work with android. Custom rom run under the android platform so the official rom may work. Custom rom and official rom, try flashing with official firmwares. If it fails try the custom
    Ready to help you
    05-12-2014 08:23 AM
  3. Saqib Rana's Avatar
    Ready to help you
    No he is not service center guy, he is technician who repair smart phones, my phone got sudden death problem, he changed EMMC chip on board and said official firmware may not work with this phone cause of changed board config so tried lots of custom roms but no harm, now 3 days ago I tried official firmware from sam mobile site, I got this problm. when I connect to Kies 3 for upgrade it gives KSA version for my mobile.
    05-12-2014 08:34 AM
  4. mobilecrackers's Avatar
    you made a mistake you should have send the phone to samsung service centre, we don't know what 3rdparty technicians will do to your phone.
    you need to find a good custom rom and install it. you can find custom rom from xda. if you need to install official firmware give your phone to samsung service centre. they will give a good service. phones like s3 will get a good service.and you will get the official firmware install it from them.
    third party technician will take out the original part from the phone and put back duplicate parts, so be careful
    Ready to help you
    05-12-2014 08:48 AM
  5. Saqib Rana's Avatar
    Ready to help you
    probably samsung has no service center here and he is my friend no worry about duplicate parts.
    anyway What I have to do is only wait for weekend to go to home and get it repaired.
    05-12-2014 09:05 AM
  6. mobilecrackers's Avatar
    its ok then. if you need a help in finding a custom rom just post it here, i am always ready to help
    05-12-2014 09:30 AM
  7. Saqib Rana's Avatar
    another problem with wifi... its showing Obtaining IP address..... but not actualy connecting.. on changing to Static IP no trafic of data..
    05-12-2014 11:11 AM
  8. mobilecrackers's Avatar
    i have the same issue with one of my router,
    check whether the modem cable are connected correctly.
    check the router settings.
    Check the DHCP (dynamic host configuration protocol) settings from router
    Ready to help you
    05-12-2014 11:18 AM
  9. Saqib Rana's Avatar
    Ready to help you
    I done it bro...thanks... keep in touch
    mobilecrackers likes this.
    05-12-2014 12:34 PM
  10. Makachaka's Avatar
    The problem is when you try to call anyone the error message says NOT REGISTERED ON NETWORK. I was fascinated this error in my Samsung phone, so I was working on this issue and trying to solve this issue.
    How To Fix NOT REGISTERED ON NETWORK In Samsung or Android Phones
    05-13-2014 04:53 AM
  11. Saqib Rana's Avatar
    The problem is when you try to call anyone the error message says “NOT REGISTERED ON NETWORK“. I was fascinated this error in my Samsung phone, so I was working on this issue and trying to solve this issue.
    hey bro any solution you found???? it is 5th day I'm facing this problem but no solution...
    05-13-2014 08:29 AM
  12. Saqib Rana's Avatar
    Ready to help you
    Hey bro suggest me best custom rom for my s3, Kit kat or JB 4.3, which is ram efficient..
    05-13-2014 08:30 AM
  13. mobilecrackers's Avatar
    this will help you
    Top 5 KitKat ROMs for the Galaxy S3 - AndroidPIT
    05-13-2014 08:41 AM
  14. Saqib Rana's Avatar
    dear how can i know that, my s3's board is changed or not??
    05-13-2014 09:12 AM
  15. mobilecrackers's Avatar
    Don't have a answer. You need to open it, I think so. Try those custom rom it may help you
    Press THANK YOU and LIKE button if you gets the answer
    Saqib Rana likes this.
    05-13-2014 09:40 AM
  16. Saqib Rana's Avatar
    how can i flash 4.0.4 to S3, it's giving error or cache and recovery after installing.. OS not starting up.. is this an error of bootloader?
    05-13-2014 02:07 PM
  17. mobilecrackers's Avatar
    is this a custom rom , you can use cwm or twrp to install it.
    if its a stock rom you can you odin as i mentioned above .
    if you had a 4.3 version before repairing, then you could not downgrade. if its a custom rom then it is ok
    05-13-2014 09:17 PM
  18. Saqib Rana's Avatar
    4.0.4 is stock rom and flashing via Odin. but I think it's bootloader problem. 4.0.4 bootloader is older not compatible with JB..
    before repair I had custom 4.3...
    05-14-2014 07:38 AM
  19. mobilecrackers's Avatar
    so its better to use 4.3 or custom rom
    05-14-2014 07:39 AM
  20. Saqib Rana's Avatar
    My frend ask me to visit him..he said efs repair would solve the problem. he's repair master. he said it will be done by Z3xBox
    05-14-2014 07:43 AM
  21. mobilecrackers's Avatar
    Its better to do that. If it is fixed let me know
    05-14-2014 07:49 AM
  22. Saqib Rana's Avatar
    I will go to him on saturday, and I hope It'll be fixed..
    05-14-2014 08:00 AM
  23. Saqib Rana's Avatar
    how can i make new thread here on this site?
    05-14-2014 08:11 AM
  24. mobilecrackers's Avatar
    go to the s3 section .you can find a post new thread button on top left or you post it here.
    05-14-2014 08:27 AM
  25. Saqib Rana's Avatar
    how can i repair my imei..or write new one
    05-15-2014 09:46 AM
81 1234
  1. Could not do normal boot odin mode
    By Shon Jacobs in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 08-16-2017, 04:25 AM
  2. corrupt jpeg email attachments on Samsung S5
    By TWERBY in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 08:33 PM
  3. Is Verizon throttling YouTube on Android?
    By alxarambula in forum General Carrier Discussion
    Last Post: 05-12-2014, 08:46 AM
  4. vzw motoX on t-mobile
    By capnfatpants in forum Moto X
    Last Post: 05-11-2014, 10:16 PM
  5. Xperis SP ext sd card problem
    By Dede Sutanto in forum Sony Xperia Series
    Last Post: 05-10-2014, 12:35 AM
