12-25-2018 12:20 PM
81 1234
tools
  1. GSDer's Avatar
    how can i repair my imei..or write new one
    You should ask that question over on XDA - there are tools that allow you to backup and restore the IMEI so I'm sure there's some way to edit it.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    Saqib Rana likes this.
    05-15-2014 10:34 AM
  2. mobilecrackers's Avatar
    you can't repair IMEI by yourself that's illegal. take your phone to your technician
    05-15-2014 10:40 AM
  3. Saqib Rana's Avatar
    finally I got my phone fixed...
    05-18-2014 09:30 AM
  4. Saqib Rana's Avatar
    dear , now how can i make backup of efs or something like this stuff to avoid like this problem and 2nd thing suggest me kitkat roms.
    05-18-2014 11:54 AM
  5. mobilecrackers's Avatar
    nee to root your phone
    How to Backup and Restore EFS Data/ IMEI on any Samsung Android Phone
    for stock rom
    Firmwares | SamMobile
    for custom roms
    just google
    I am taking a 2-3 week or months leave. see you after that ...
    Saqib Rana and GSDer like this.
    05-18-2014 12:01 PM
  6. Saqib Rana's Avatar
    for stock rom
    for custom roms
    just google
    thanks and may you have happy leave. see ya
    mobilecrackers likes this.
    05-18-2014 12:15 PM
  7. Saleeth Ahmed's Avatar
    Dude i need to know how u got ur s3 fixed
    niladrispal likes this.
    06-09-2014 08:51 AM
  8. Sandip Patel7's Avatar
    07-20-2014 01:26 PM
  9. Muhammad Zubair Saeed's Avatar
    Hi Saqib, I am on I9300XXUGNB6_I9300OJVGNB3_PAK
    and only this method by Zaroon worked for me. ([How TO] Solve Not Registered on network Galaxy S3 I9300 issue and restore IMEI | Androidveterans)
    FIXES:
    The Device will connect to the network right away after applying the fix.
    IMEI number will be restored.
    Files Required:
    XXUGMK6 Modem.zip (Click here)
    XXUGMK6 Kernel.zip (Click here)
    Download and copy the files in Phone’s internal storage. The files must be in .zip format.
    Pr-requisites:
    As usual, creating backup is the first priority:
    Create backup of apps, music and other stuff.
    Create backup of your text messages and contacts.
    Enable USB debugging in Settings under the Developer Options.
    Your device should be rooted and should have ClockworkMod (CWM) installed in it. (Click here, ignore the title. works with all Android versions.)
    And lastly, check your battery, it should be almost 70% charged.
    Steps to solve “not registered on network” issue on Galaxy S3 I9300:
    Turn the device off and reboot in recovery mode. Press and hold volume up+power+menu button until device enters in recovery mode.
    When in recovery mode, go straight to “install zip from sdcard” and select” chose zip from sdcard. Select XXUGMK6 Kernel.zip and confirm the installation. wait until installation completes.
    Similarly, again go to ” select zip from sdcard” and chose XXUGMK6 Modem.zip already copied in internal storage and proceed with “Yes” to install it.
    After both above patches have been installed, reboot the device in normal mode. As soon as device reboots, it will get registered to network and IMEI number will be restored. You are now good to go for making calls and sending text messages.
    07-20-2014 02:46 PM
  10. Akash Kothari's Avatar
    Hie m akash from India. I was using 4.3 version on my S3 but it had battery drain problem so i downgraded it to 4.1.2 using odin since then its showing not registered on network problem. i tried to upgrade it again with the help of odin but the problem still lies. please help me. thank you
    08-15-2014 12:47 AM
  11. Akash Kothari's Avatar
    Will Kies detect my phone when theres no battery in it?
    08-15-2014 12:49 AM
  12. GSDer's Avatar
    Hello and welcome to the forums!
    That depends - if you have the phone turned on and connected to your computer and THEN remove the battery, yes, Kies will still see the phone. But if the phone is turned off and you remove the battery and then attempt to turn it on, that won't work (and of course Kies won't see the phone if it's not turned on).
    08-15-2014 11:54 AM
  13. Hamdullah Khan's Avatar
    Hello Saqib,
    How did you fix your phone, I have the same issue, my phone works ok with mobilink but not with zong or any other network.
    Thanks
    Hamdullah
    08-27-2014 12:35 PM
  14. Satyam Soni1's Avatar
    when i remove battery while connecting my phone to pc it shuts down
    09-30-2014 01:12 PM
  15. dankell's Avatar
    Thank you for this Fix . I have searched the net for a solution for this terrible bug and your method fixed my problem.
    I really cant thank you enough and I just had to register to give my thanks.
    You Sir are a true GENIUS!!! and you have made my son a very happy young man again.
    Fantastic work my friend and again...A BIG THANK YOU SIR!!!
    Best Regards.
    10-09-2014 11:27 PM
  16. Marcelup's Avatar
    I am from Brazil and I am facing a similar problem to Saqib Ali.
    I bought a second hand Galaxy SIII and after some weeks it cannot access TIM operator anymore.
    Checking different internet sites I learned that:
    1. The Android version was updated to 4.3
    2. The IMEI in the back of the phone is not the same as the one presented when I call *#06#
    3. The phone was rooted
    I don't use to change the genuine characteristics of any of my devices. I am very conservative and what I would like to do is to bring my mobile back to its original condition and fully working.
    I could proceed how you guided Saqib Ali to do but I realized that I will need your help to finish the whole procedure.
    Best regards,
    Marcelup
    10-11-2014 05:59 PM
  17. Anil Kumar85's Avatar
    Hi frnd,
    my mobile is showing problem with the network search. Earlier the message pop off was,.. Reset by IPC TIME PUT. plz get RIL...
    After that i have done the software update from Samsung store. then also the problem still. "mobile network not available." plz help..
    11-10-2014 01:56 PM
  18. Anil Kumar85's Avatar
    plz , saqib ali. tell how you resolve the network issue..
    11-11-2014 10:23 AM
  19. adnan malik1's Avatar
    guys i am facing the same problem but my imei no is same my searial no in settings is ooooooooooo ican;t call or sms can you help me and your method work for serial no recover or not
    12-11-2014 03:13 PM
  20. dnumyar06's Avatar
    Bro. How you fix this issue we have the same probs..
    12-14-2014 10:23 PM
  21. Dyepoy2014's Avatar
    Hi Sir, I have also the same problem. Please tell me how your phone got fixed ..
    01-13-2015 07:48 PM
  22. AliQ1980's Avatar
    I have the same problem Mr. Saqib Rana. I am from Pakistan as well. could you please help me???
    01-31-2015 04:18 AM
  23. randypolanen's Avatar
    i've done everything with kies but now the same problem en i've gotten an other serial number what can i do now i can use my phone for olmost 3 weeks no calls and no sms nothing only wifi????please help me its killing me
    03-26-2015 06:51 AM
  24. Chirag Ghalot's Avatar
    how to solv the problem of no network
    05-12-2015 12:41 AM
  25. Julio Botelho's Avatar
    I am get a message telling "'GT-I9300' do not support initializing."
    06-22-2015 03:18 PM
81 1234
  1. Could not do normal boot odin mode
    By Shon Jacobs in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 08-16-2017, 04:25 AM
  2. corrupt jpeg email attachments on Samsung S5
    By TWERBY in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 08:33 PM
  3. Is Verizon throttling YouTube on Android?
    By alxarambula in forum General Carrier Discussion
    Last Post: 05-12-2014, 08:46 AM
  4. vzw motoX on t-mobile
    By capnfatpants in forum Moto X
    Last Post: 05-11-2014, 10:16 PM
  5. Xperis SP ext sd card problem
    By Dede Sutanto in forum Sony Xperia Series
    Last Post: 05-10-2014, 12:35 AM
