1. TanzD's Avatar
    Hi all,
    My case-less samsung s3 fell from a bag off a 3 foot table onto tiled floor. I've now done a reset by holding the top volume, home and power buttons and it restarted normally with the led lights and buttons vibrating. I can even see some of the lock screen and it appears normal. However most of the screen is black or pixelated and the whole phone does not respond to touch at all, anywhere. Is there a chance of fixing this (preferably without erasing data), just replacing the screen or will I have to get a brand new replacement?
    Thanks s much in advance
    09-18-2014 11:54 AM
  2. Almeuit's Avatar
    If you know of a reputable repair shop in your area they can most likely fix the screen without messing with the data on the phone itself.
    09-18-2014 12:52 PM
  3. GSDer's Avatar
    Welcome to the forums!
    Yes, there's a very good chance of fixing it by replacing the complete screen assembly. You can check out sources like
    http://m.repairsuniverse.com/samsung...ent-white.html
    http://www.etradesupply.com/samsung-...-assembly.html
    or Google it and see if you can find a less expensive solution.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    09-19-2014 02:39 AM
  4. Salman Salu1's Avatar
    My s3 signal problem the signal is full and 1 se ago and signal is lost you can tell me its hardware or software problem.......
    09-19-2014 08:42 AM
  5. B. Diddy's Avatar
    See here for response: http://forums.androidcentral.com/sam...l-problem.html
    09-19-2014 02:49 PM
  1. How can I revert from Kitkat to Jelly Bean?
    Last Post: 09-18-2014, 05:03 PM
  2. How can I clean the screen of my Tab Pro 10.1?
    By DukeOfURL01 in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 09-18-2014, 03:02 PM
  3. S-View Case for Galaxy S5 Help
    Last Post: 09-18-2014, 02:01 PM
  4. How to Split Navigation and Status Bar on the Bottom (Tablet UI)?
    By too lame to come up with a good username in forum Google Nexus 7 (2013) Rooting, ROMs, & Hacks
    Last Post: 09-18-2014, 01:53 PM
