1. Saucelace's Avatar
    it is a pebble blue galaxy s3 from verizon. i replaced the screen and now the lcd won't light up. the screen was attached to the phone with a small copper colored ribbon in the bottom right corner of the phone. i removed some of the glass when i pulled off the ribbon. is there a way to fix it?
    10-16-2014 11:01 AM
  2. Byron 5's Avatar
    Look on the website iFixit
    10-16-2014 11:37 AM
  3. GSDer's Avatar
    Welcome to the forums!
    Do you mean that you replaced the glass (the outer layer) or that you replaced the whole screen (glass + digitizer + AMOLED display)?
    If the latter, did you replace the complete screen assembly (including the front frame)?
    Did you use a brand new part?
    It sounds like you didn't hook something up correctly but it's hard to say without more information.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    10-16-2014 11:45 PM
  4. Jack Moon's Avatar
    I replace glass for the Galaxy S3 all the time, and I've been doing fine. I also have succeeded in replacing the glass on the Note 2 as well. However, I find some of Galaxy Note 2 LEDs don't work after a glass replacement—indicating I must have caused some damages to the LED.
    I don't see any cracks, and I only apply 70 °C of heat to loosen the adhesive. And, I use the trusted iFixit spudger to remove it with the same method that I apply to the Galaxy S3—but I find that 3 out 10 times, I will have a problem with the display.
    09-05-2017 07:43 AM
  1. Nexus 9 compared to Samsung - Galaxy Tab Pro 8.4
    By gtt1 in forum Google Nexus 9
    Last Post: 02-06-2015, 05:13 PM
  2. Why has my Nexus 5 reset itself?
    By silvershadow1x in forum Google Nexus 5
    Last Post: 10-16-2014, 07:59 PM
  3. ok google hi galaxy offline
    By bsettz in forum Samsung Galaxy S5
    Last Post: 10-16-2014, 01:19 PM
  4. How can I recover my WiFi key without rooting my LG G2?
    By WillisOfficial in forum Ask a Question
    Last Post: 10-16-2014, 11:22 AM
