1. Josiah Brown1's Avatar
    i tried flashing cm onto my rooted galaxy s3 using the oneclick app, and it's stuck on a screen that says cyanogenmod with the little blue guy and a rotating arrow. i've restarted it several times and volume up, home and power buttoned it (i dont know what the mode that puts it in is called) and it comes up the same. how can i fix this? i'm happy for it to go back to android or to cyanogenmod i just don't want it to be in the middle
    thanks
    10-19-2014 04:00 AM
  2. GSDer's Avatar
    Welcome to the forums!
    I'm not familiar with the one click app. What firmware did you have on the phone before attempting to load CM?
    Model number/carrier?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    10-19-2014 12:00 PM
  3. Josiah Brown1's Avatar
    it was on Android 4.3, i9300t with telecom new zealand, but it's all good now, it just needed more time to boot into CM for the first time, thanks for your help
    10-22-2014 02:22 AM
  4. stephaninberlin's Avatar
    Hi, I have same problem. How long did cyanogenmod take to boot on first use for you? Thanks for your help.
    10-31-2014 10:49 AM
