1. too lame to come up with a good username's Avatar
    I'm going to replace the back cover of my Galaxy S3. I'm looking at either a brushed aluminum back plate, or a pleather back. I don't like to use phone cases, by the way.
    Brushed aluminum pros: Feels extremely premium. Could protect the phone pretty well.
    Cons: The metal might interfere with the cellphone signals. Might scratch easily. Metal is not grippy.
    Pleather pros: Feels more premium than Samsung's glossy plastic, but not as premium as aluminum. Won't scratch as easily. More grippy than plastic or metal.
    Cons: Won't protect the phone as well as aluminum. Might make my hand sweaty in hot weather.
    I heard that aluminum phones scratch really easily, is this true? I'm not sure what to get! Opinions? What would be best for a smartphone? Samsung is making some Galaxy devices with faux-leather backs... maybe there's a good reason for that?
    10-25-2014 11:12 PM
  2. GSDer's Avatar
    I'm no RFI engineer, but I'd change 'might' to 'will' - metal that wasn't part of the design is going to cause interference with the various antennas. At best you'll get a lousy signal; at worst you'll burn up the power amplifiers.
    "But other phones have metal cases!" you might say - true, but that was part of their design from the ground up: they use the metal case as part of the antenna setup.
    Regarding the other con - just take your keys and run them on the case of a demo M8 in one of the stores - that's what'll happen to your pretty case when you put it in your pocket.
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
    10-25-2014 11:51 PM
  3. AxlMyk's Avatar
    There have been many threads about metal cases causing radio problems
    AC App on SGS3
    10-28-2014 03:21 PM
  1. Is your case scratching the chamfered aluminum edge on your Note 4?
    By 91DBrown in forum Samsung Galaxy Note 4
    Last Post: 03-14-2016, 11:00 PM
  2. Replies: 15
    Last Post: 10-28-2014, 03:27 PM
  3. Replies: 2
    Last Post: 10-25-2014, 10:04 PM
  4. Replies: 0
    Last Post: 10-25-2014, 08:43 PM
  5. Why aren't my Soft Keys working on my Note 4?
    By wulfstr14 in forum General Help and How To
    Last Post: 10-25-2014, 08:24 PM
