Use code Android10 andsave 10% on your first Upsie warranty
  1. Dini House's Avatar
    One thing that causes massive draining is playing Clash of clans ( after 5 min. It drains about 15 %)
    But even if i dont play it , after charging at 1 am , i wake up at 9 am , and its 85% , even with airplane mode and wifi turned off
    Note: i always keep bluetooth, sync , s-beam, smart stay off ...
    It even charged slow (8 hours for a fill recharge) but i fixed it by making minor changes on when i charge the phone
    Any help with the drain issue would be appreciated
    12-11-2014 02:16 PM
  2. Dini House's Avatar
    Airplane mode on*
    12-11-2014 02:25 PM
  3. Gaba517's Avatar
    Go to Settings>Battery and take a screenshot, we need to see what is draining the battery.Do it when the battery has like 20% left.
    12-12-2014 12:27 AM
  4. Dini House's Avatar
    Today i played clash of clans for only about 12-13 minutes , cus its always above 40%
    Attached Thumbnails Why does the battery of my Galaxy S3 drain like crazy?-screenshot_2014-12-12-17-11-42.jpg   Why does the battery of my Galaxy S3 drain like crazy?-screenshot_2014-12-12-17-11-52.jpg
    12-12-2014 10:14 AM
  5. PoisonDarts8714's Avatar
    That isn't specific enough unfortunately. Go to the PlayStore and download GSAM Battery monitor. Go into settings of said app and turn on start on boot (i.e active monitor) charge to full and use normally..Then post screenshots of that, then 'app usage'
    12-13-2014 10:16 AM
  6. Dini House's Avatar
    Dammit i had 100% ...shut down my phone
    Turned it on after an hour and it had 92%
    12-13-2014 11:29 AM
  7. Gaba517's Avatar
    I'm almost sure it's a bad battery if it drains like that even when the phone is completely turned off, you should try another battery and see if it behaves the same.
    Posted from my beast Note 3
    12-14-2014 05:32 AM
  8. AxlMyk's Avatar
    Or charge it to 100%,and remove the battery. Then see what it says the charge is after several hours.
    AC App on SGS3
    12-14-2014 08:13 AM
  9. trickedempire's Avatar
    My s3 does the same it was at 100 at 9pm its 10:52 and its at 5
    06-09-2015 09:52 PM
  1. Why is my battery life on my Samsung Galaxy Tab4 10.1 so terrible?
    By andrewgale99 in forum Samsung Galaxy Tab4 10.1
    Last Post: 01-17-2015, 10:30 PM
  2. Why does my Vodafone N985 keeps exiting it's sd card?
    By Pedro Morgado in forum Vodafone
    Last Post: 12-11-2014, 09:46 PM
  3. Replies: 1
    Last Post: 12-11-2014, 02:08 PM
  4. Replies: 0
    Last Post: 12-11-2014, 01:03 PM
