my samsung galaxy s3 won't connect to the wifi
my power button wasn't working and i saw a youtube video that said that it happens often and that an easy fix is to just go into the hard drive and take it out and use an app to turn off the screen. i did that and now the power button isnt a problem but after i did that i accidentally activated the custom os option i quickly pulled the batter and started it up right and everything seemed to work fine except the wifi.
so if you have any suggestions or ways i can fix this i would be very grateful
please don't say just you your mobile web because i have very limited web for each month
