1. crazy4red8's Avatar
    I bought this phone within the past month and I don't know when it stopped working. I have tried taking pictures with the flash on and auto, but it is not flashing at all.
    02-03-2015 07:49 PM
  2. UJ95x's Avatar
    Welcome to AC
    I'm guessing your battery isn't low? If it is, you won't be able to take pictures with flash.
    Have you tried the flashlight widget to see if it works that way?
    02-03-2015 08:09 PM
  3. crazy4red8's Avatar
    The flashlight would work either and no the battery isn't low either.
    02-03-2015 08:18 PM
  4. UJ95x's Avatar
    Sorry, I think you meant to type "wouldn't," right?
    02-03-2015 08:34 PM
  5. Nurul Atikahh96's Avatar
    I have a problem wich is my camera flash not working. I have turn it on, so it turning on but there are no flash at all. So I tried to turn on flashlight, it's same! Both not working!! Hwarghhh. Help me ASAP I'm using xperia z
    08-21-2015 05:35 PM
  6. javan ormsby's Avatar
    06-20-2016 06:30 AM
  7. javan ormsby's Avatar
    06-20-2016 06:39 AM
  1. Replies: 140
    Last Post: 07-16-2015, 04:30 PM
  2. Replies: 1
    Last Post: 02-04-2015, 01:08 AM
  3. hello need a little help for my daughter
    By waterman74 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-03-2015, 08:11 PM
  4. How can you tell if your phone is unlocked from AT&T?
    Last Post: 02-03-2015, 07:37 PM
  5. flashing screen
    By JNGrooms in forum Samsung Gear Fit 1 & 2
    Last Post: 02-03-2015, 07:25 PM
