1. Hayley Carew's Avatar
    So basically I noticed that the Instagram App on my phone was missing so went to click on playstore and what popped up was "playstore has stopped working" So I have been googling for over an hour for solutions! I have tried
    Open settings, click the more tab (Top right) click application manager swipe from right to left till you get to ALL find the Google play store in the list click on it
    click the button that says clear data (Don't worry your apps won't go any where)
    then launch the play store again also clear cache and uninstalled the latest update! Nothing has worked! Now its not showing up in application manager! Can anyone help! Oh and I contemplated Factory reset and it needs a pin...must have set one but cant think of it! It is also a Samsung Galaxy S3!
    02-06-2015 02:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try a cache partition wipe, which won't erase any personal data: http://forums.androidcentral.com/sam...2-s3-tab2.html
    02-06-2015 07:30 PM
  3. ghoste mane's Avatar
    hello my samsung j7 updated the phone and since then I cant get any of my apps in play store to update nor will they work at all took phone back to store they fixed it they did not what do I do
    11-07-2019 10:41 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Did you ask the store what they did?
    11-07-2019 12:48 PM
  1. How do I remove my network provider off my status bar?
    Last Post: 01-25-2018, 04:54 AM
  2. Replies: 1
    Last Post: 02-06-2015, 07:41 PM
  3. Why is my Digix Android Tablet screen white?
    Last Post: 02-06-2015, 04:59 PM
  4. Which running belt will fit my Galaxy Note 4?
    Last Post: 02-06-2015, 02:07 PM
